Gas Guage Advise
92 Honda Accord gas gauge always stays on full. My censor to the gas gauge is fine, but have no idea why it doesn't work. Can somebody please help!
have you checked the fuel level sending unit? iirc in cb there is access panel to the level sending unit? you checked that?
you pull the speedo cluster? did the fuel gauge receive power/ lose power when unplugged or plugged?
anything in between that could be wiring/ relay issue.
have you checked the fuel level sending unit? iirc in cb there is access panel to the level sending unit? you checked that? you pull the speedo cluster? did the fuel gauge receive power/ lose power when unplugged or plugged? anything in between that could be wiring/ relay issue.
The gauge in the car is what I was referring to. It's stays on full whether the car is on or not. I check the fuse box and the all the fuse are fine.
Hiroshima_VTi-S
May 30, 2007 10:35 PM
accordinglyevil
Aug 15, 2005 10:17 AM
