Help me with...Clutch Mstr Cylinder supercede part needs a different steel "A" line
Old Dec 28, 2013 | 06:38 AM
safedriver's Avatar
Default Help me with...Clutch Mstr Cylinder supercede part needs a different steel "A" line
Has anyone, recently bought an oem CMC and run into this?
My daughter's 01 type r lost its clutch fluid, from its reservoir.
I found it under the carpet.
I am trying to buy an oem CMC (46920-st7-a01, for $102.20), but there is a bulletin with a new part number (06469-st7-305, for $79.80).
1. The old part is called a "Clutch Master Cylinder Assy" ($102.20), but the replacement part is called a "Clutch Master Kit" ($79.80).
2. The bulletin calls for this new part number (06469-st7-305) to be accompanied by a replacement steel Clutch "A" Line (06469-st7-308, for $8.05).
Question: Isn't a "Kit", just a rebuild kit, full of washers and seals, AKA $79.80?
Question: Why would a "Kit" need a different steel Clutch "A" line?
Old Dec 28, 2013 | 01:13 PM
94rs-turbo's Avatar
Default Re: Help me with...Clutch Mstr Cylinder supercede part needs a different steel "A" li
seen that before Im pretty sure you dont need it, might have to slightly bend the line no biggie
the new p# 06469-ST7-315 I can get for you runs 75 plus shipping(retail is 109.97)
I work for Acura dealer in plano TX
Old Dec 28, 2013 | 04:42 PM
safedriver's Avatar
Is the Clutch Master Kit (xxxxx-st7-315) an actual master cylinder, for $75ish ?
Old Dec 28, 2013 | 07:38 PM
94rs-turbo's Avatar
yep the P#305 supersedes to the 315 #
jdm kidd
Jan 15, 2011 06:07 AM
jdm kidd
Jan 14, 2011 08:22 AM
playlife
Jul 8, 2010 07:07 PM
AFAccord
Oct 26, 2007 04:48 AM
