Climate controls do not work.
Old Dec 27, 2013 | 03:02 PM
Joshboom2488's Avatar
Default Climate controls do not work.
Hi, I just installed a new aftermarket radio into my 1997 Honda civic coupe dx car. It already had one in there before but i didnt like it so i got a new one. I hooked everything up wire for wire and the stereo works great. But now none of my climate controls work at all. I cant even turn on the ac or anything. what could be my problem?
Thanks Josh
Old Dec 27, 2013 | 06:42 PM
goldsy's Avatar
Since you just installed a new stereo right above the climate controls, I would first check to see if you knocked a plug loose on the controls which can very easily be done when you stuff all the wires back into the slot. If everything worked before the stereo install, I can't really see it being anything else at this point. It would be a remarkable coincidence if your blower fan died or the fuse blew at the same time. Assuming you still have stock climate controls for the 97 (I put 99/2000 controls in my 97 hatch years ago) do the lights come on above each vent setting button when you press them?
Old Dec 28, 2013 | 09:05 AM
Default Re: Climate controls do not work.
No none of the lights work when I press any buttons at all. ANd Ill check the plugs here in a few and get back to you on that.
Old Dec 28, 2013 | 11:08 AM
goldsy's Avatar
If the plugs are secure, make sure it wasn't just a wire knocked out of the harness.
Old Dec 28, 2013 | 11:25 AM
Yeah the plugs were secure and after double checking i saw no wires out of the harness. Also if it was a fuse wat ones could i check to see if they are bad? Thanks for the help .
Old Dec 28, 2013 | 12:17 PM
goldsy's Avatar
I'd start with the heater/ ac relay 7.5amp under the dash first. But like I said, it would be quite the coincidence if the fuse for the climate controls blew at the same time you installed a stereo but stranger things have happened.
Old Dec 28, 2013 | 12:57 PM
I went ahaed and just checked all fuses and all are good. The lights where you can chamge between hot and cold work but there are no lights on the buttons and the blower motor switch does nothing as well.
Old Dec 28, 2013 | 01:58 PM
95Sedan's Avatar
I bet while taking the lower console out (if you did) you forgot to plug a harness in.
check a 3rd time
take it all apart and do it again
Old Dec 28, 2013 | 02:41 PM
Theres only two harnesses that go to the switch. Then they conjoin into one big plug and thats it. Aldo can someone give me a wire diagram for this? Thanks
Old Dec 28, 2013 | 04:15 PM
I found my problem. It was a missing fuse. Thanks for all ur guys input.
Moms 94
Nov 2, 2013 08:12 AM
bonboncito
Jan 27, 2012 12:11 PM
CRXDaddy78155
Oct 3, 2006 12:14 PM
aw1234dude
Oct 31, 2003 08:38 PM
devonic
Jan 28, 2003 07:22 AM
