Removed my P/Steering, drain it or loop?
Old Dec 27, 2013 | 12:44 PM
Steeve_Civic's Avatar
Default Removed my P/Steering, drain it or loop?
I've just removed my P/S and asked me a question about drain it or leave some fluid inside and make a loop like that
I've tried to loop like that but there is some air and fluid inside the rack, don't know if it is the way to go.
Old Dec 27, 2013 | 01:36 PM
10sec4door's Avatar
Default Re: Removed my P/Steering, drain it or loop?
I turned the steering wheel completely to the left and right left remaing fluid in it with a loop never had a problem
Old Dec 27, 2013 | 03:27 PM
Turbo-LS's Avatar
I personally ditched mine all together and put in a manual rack which shaves a fwe mor pounds off from a power rack. ther is a way to completely convert a PS rack to manual but the turning gear ratio isnt designed for manual operation so its not as easy as a manual rack
Old Dec 27, 2013 | 05:14 PM
$MIKE$'s Avatar
You have a 3rd gen or 2nd, all you needed was annual rack out of a eg or rs integra?
Could I do it with the motor in?
Btw I looped p/s and never had a prob with it.
Old Dec 27, 2013 | 05:46 PM
Turbo-LS's Avatar
I have a DC and I'm running an EG manual rack. You also need the universal joint from the civic and then modify the pass side rack mount. I just added more rubber and it worked out fine. You can do it with motor in the car
Old Dec 27, 2013 | 06:01 PM
gringotegra's Avatar
I took everything out of it, didn't loop it or anything. Been fine for 4 years now lol
Old Dec 27, 2013 | 08:35 PM
jdm inc's Avatar
i put a manual rack in mine.
Old Dec 28, 2013 | 02:13 AM
No need oil at all?
Old Dec 28, 2013 | 08:45 AM
da_dude's Avatar
This is how I'll be doing to my PS rack.
https://honda-tech.com/forums/showth...677&styleid=14
Old Dec 28, 2013 | 09:22 AM
93ericSi's Avatar
If you keep the power rack then it will be more work to turn. Looping it works to keep crud out but doesn't improve anything.
Manual rack is the way to go and I picked one up for my EG at the junkyard for like $30. Been working great for 3 years.
-Eric
Old Dec 28, 2013 | 09:28 AM
SPOOLINmatt's Avatar
over time it gets easier to turn if its a power rack. I didn't even realize my rack was a power rack until 6-7 years after owning my current civic because there was never any excessive force needed to turn.
Old Dec 28, 2013 | 09:33 AM
rudebwoy's Avatar
I replaced the rack with a manual one, feels natural even with slicks.
Old Dec 28, 2013 | 11:00 AM
Originally Posted by Steeve_Civic
No need oil at all?
Nope, just left it all open.
kevinmcc2
May 16, 2013 02:53 PM
95JDM
Nov 5, 2008 05:03 PM
95blackEG
Oct 17, 2008 02:10 PM
DOHCon15s
Jan 17, 2004 07:57 AM
