Honda S2000 Honda S2000
Rattling sound on start up
Old Dec 27, 2013 | 09:24 AM
honda_4life_'s Avatar
Default Rattling sound on start up
Have a 2003 s2000 and when I start the car for the first time when it's cold it starts with a nasty rattling sound !!! I don't know what it is, it could be the starter coil not retracting in time but I'm not sure any professional opinions?
Old Dec 27, 2013 | 10:17 AM
beandip's Avatar
Default Re: Rattling sound on start up
Post a video of it. It could be anything with that type of description.
Old Dec 27, 2013 | 10:33 AM
Old Dec 28, 2013 | 08:18 PM
No one?!?
Old Dec 28, 2013 | 09:00 PM
pettyboy69's Avatar
Sounds like rod knock to me since it does it at startup and goes away once the motor see's oil pressure, Could also be the tct but they usually continue to make noise after starting
Old Dec 28, 2013 | 09:07 PM
A rod knock would mean it would knock regardless and is much worse then this.
Old Dec 29, 2013 | 08:59 AM
BLacK FirE's Avatar
Kinda hard to tell from the video, but does it only do it when it's cold outside? Might be the starter like you said. If you search it on s2ki you'll find other videos of people with the problem as it seems to be pretty common.
Old Dec 30, 2013 | 07:19 AM
B16-CRX's Avatar
Hard to tell from the video, but it kinda sounded like a starter getting hung up. Did you ever hit the start button while the car was running by accident?
Old Dec 30, 2013 | 07:29 AM
Yeah my gf did when she tried to drive it -_-
Old Dec 30, 2013 | 09:39 AM
B16-CRX's Avatar
You might want to start with replacing the starter and take it from there. If damage was done to the flywheel, you will need to replace that as well unless you can live with the noise. The teeth on the ring gear might be chewed up.
Old Dec 30, 2013 | 01:17 PM
JulieU's Avatar
Sounds like the starter sticking. Mine (also a 2003) started doing that but it only did it when it was cold and dry out, didn't do it if it was hot/warm or humid out. I replaced mine with a used AP2 starter almost two years ago and have had no issues since.
Old Dec 30, 2013 | 01:43 PM
Thank you ! Il get a new starter and update thread !
Old Jan 5, 2014 | 01:10 PM
It was a bad starter
Old Jan 7, 2014 | 04:10 PM
Arsenal's Avatar
Lol at rod knock
Old Jan 24, 2014 | 10:40 AM
turnsignalandy's Avatar
Good to know. Just picked up a MY05 and it has the exact same issue. Are starters hard to replace on these?
Old Jan 24, 2014 | 11:50 AM
Boots's Avatar
its not hard, theres just a bolt that's a real pain in the *** to get to
Old Jan 25, 2014 | 07:42 PM
pettyboy69's Avatar
Originally Posted by Arsenal
Lol at rod knock
Obviously no one here has had a motor with bad rod bearings, I've had probably 5 engines that made a knocking noise on start up for the first couple seconds then goes away and is silent no matter the rpm afterwords. Then after pulling the motor apart bearings were toast along with the crank. I'm not an idiot
Glad to hear OP got it figured out
JdmJellyBeanEG
29
Jul 29, 2012 05:14 PM
EJ1_CRIS_909
Mar 16, 2012 02:41 PM
caleb423
Engine Management and Tuning
Jun 22, 2011 06:45 PM
no_one_
Oct 11, 2004 05:59 PM
MrEg
Sep 1, 2003 09:32 PM
