S2000 Rear end vibration under acceleration
Have a 2003 honda s2000 and at about 38-50 mph I have a vibration that seems like it is coming from the rear under acceleration and doesn't vibrate when I let off the gas.
I HAVE ALREADY:
Replaced BOTH cv axles with brand new axles.
Gotten a wheel balance
Had axle spacers and removed them.
Swapped rims to see if it was the tires
STILL VIBRATES!!!! GETTING VERY OLD !!! Please help??
I HAVE ALREADY:
I hope you didn't toss your old axles...the OE axles are hollow shaft, almost all aftermarket shafts, even if theyre from the same manufacturer as OE, are going to be solid...which wont get rid of the vibration...if you still have your old axles, swap the inner buckets that go into the diff from left to right and your vibration will be gone
P.S. what the **** did you go over to scrape that tube frame so bad?
Well the axle I bought looks EXACTLY the same as the oem axles so I'm pretty sure these axles are hallow shaft as well?
And my friend was driving my car as I bought a truck we were on the way back and he spun out and went over a curb !
Look what do you have to change is the cv bucket
Look why the car shaking the piece is worn.
Heres a link with pictures
https://honda-tech.com/forums/showth...111&styleid=14
