what factory pistons to raise compression in d15b7?
i'mm looking to pick up a little horsepower in my dx motor by raising the compression ratio. What ratios will different oe pistons give me on a stock motor? i'm shooting for 10-11 to 1. Thanks.
ZC pistons, and I believe 88-91 integra pistons. There's alot if info if you search around. Maybe just as much info as there is for DOHC motors
Just search my friend and you will find
d16a6(si) or ZC. For more info, try ezboard.com in D series forum.
[Modified by SILINITY16, 6:25 PM 10/28/2002]
I've searched all over this site. but I have not found the info i would like. Thank you for the forum.
the D16A1(ZC) pistons, will raise your compression 1/2 a point. You can pick those up from HOnda for about 130 bucks a set
fdjizm
Dec 10, 2006 10:04 AM
89civichatchback
May 28, 2003 08:38 PM
