IMW-Built/Tuned: 85mm B-Series Daily Driver
Old Dec 26, 2013 | 04:53 AM
D-Rob's Avatar
Default IMW-Built/Tuned: 85mm B-Series Daily Driver
It's been a while since I have posted anything here, and wanted to share the results of a small customer job we just completed.
The customer was looking for a naturally-aspirated B-Series project that had enough power/torque to have some fun, but still retain all comforts of the daily-driving useability (air conditioning, power steering, quiet exhaust, etc).
We set the goal around 220whp, expecting the smaller 2.5" exhaust with large-volume resonator and muffler to hinder flow a bit. We also were looking to keep the revs conservative, for reliability concerns (nothing over 8,600rpm for this engine).
The engine setup consists of the following:
B20 block (stock sleeves)
CP Pistons (85mm, PN#SC7119)
Eagle H-Beam rods
Clevite bearings
OEM Honda oil/water pumps
ARP head studs
Golden Eagle LS/VTEC conversion kit w/head gasket
GSR P72 cylinder head (stock casting)
SuperTech valves/springs/retainers
Underground Racing BC4-Spec camshafts
Blox intake manifold
Skunk2 Alpha throttle body
IMW-Spec 3" cold air intake
PLM "RMF-Style" header
IMW-Spec 2.5" stainless exhaust
Injector Dynamics 725cc injectors
Tuned in-house by John Kerr @ IMW with Hondata S300
The results surprised us a bit, surpassing the projected power output on 93 octane with ease.
The final numbers were 232whp / 160wtq.
The car has ample torque at any engine speed, which is a plus for our customer using this as a daily driver. The exhaust note is also very docile; the valvetrain is actually louder at idle and cruise loads.
The power this engine made is what we normally see engines with much higher compression and ported cylinder heads make here, thus why we decided to share it with everyone!
Thank you for viewing! If you have any questions, feel free to ask.
- Derek
Old Dec 26, 2013 | 05:06 AM
89si-rex's Avatar
Default Re: IMW-Built/Tuned: 85mm B-Series Daily Driver
Good numbers, can not wait until I drop off my motor for assembly, you and John are awesome at imw, which is why every single one of my friends gets tuned there. Keep up good work guys.
Old Dec 26, 2013 | 08:43 AM
d16z6Tcrx's Avatar
very nice build and great power!
Old Dec 26, 2013 | 10:55 AM
Uncle Dave's Avatar
It must be xmas Derek has posted,great job as always from you mate your threads are always good to read and a credit to you and your shop.
Old Dec 26, 2013 | 02:12 PM
93egSLEEPER's Avatar
Ported head and a "bigger" header and I think 250 is attainable. Very impressive build. Every time I see a B20V build this simple with great results it make me more excited to finish mine up. Great job guys
Old Dec 26, 2013 | 03:29 PM
DDTECH's Avatar
Good job Derek, Great results. What were the final gear settings and overall timing for this setup?
Old Dec 27, 2013 | 07:38 AM
DA-NINE's Avatar
If you're able to could you tell us more about the cams?
Old Dec 27, 2013 | 07:41 AM
AaronEJ's Avatar
nice build.
i like the torque curve , pretty flat with no big "dead spots"
must be fun to drive
Old Dec 27, 2013 | 08:42 AM
koczeka's Avatar
Good, could be better if U replace that junk header with a TODA replica.
Old Dec 27, 2013 | 09:49 AM
Charlie Moua's Avatar
solid power
Old Dec 27, 2013 | 05:34 PM
93ls10.0's Avatar
What is the compression in this thing?
Old Dec 28, 2013 | 04:23 AM
D-Rob's Avatar
The cams were at -1 IN, +2 EX, I believe. Couldn't tell you table timing values, John tuned this one.
They're supposedly the same grinds as the Buddy Club Spec 4's (and I wouldn't be surprised if they come from the same place).
CP rates the pistons at "11.5:1", so with the GSR head, we'll say 11.6-11.8:1?
Old Dec 28, 2013 | 04:51 AM
DA-NINE's Avatar
Thanks! that thing is making some power. Why did you guys choose a 2.5in exhaust instead of a 3in? especially on a 2.0l
Old Dec 28, 2013 | 06:26 AM
whitesihatch's Avatar
^for daily driver comfort, is the only thing I can assume lol. Car has serious solid power. Great power band.
Old Dec 28, 2013 | 07:48 AM
MugenSpeclNY's Avatar
RMF narrow really that bad on a 2.0 set-up? I have one on my 1.8 and I was happy with it nice up top power.
Old Dec 28, 2013 | 08:58 AM
Golding.racing's Avatar
wow great figures, i'd be over the moon if my +1mm bore f20b made near that.
Old Dec 28, 2013 | 09:07 AM
xSteve_Ox's Avatar
pm'd you Derek about my similar build with Spec 3+, good numbers here
Old Jan 7, 2014 | 07:06 PM
vtecmasta85's Avatar
Eagle H-Beam rods
Clevite bearings
ARP head studs
IMW-Built / Tuned : 85mm B20/VTEC Integra - YouTube
- Derek
I didn't know that underground racing still made custom cams. Are they any different from the original ones? Power curve is nice and sounds to have good midrange.
Nice stuff!
Old Jan 7, 2014 | 10:39 PM
HNL.eg6's Avatar
this makes my ITB numbers look like sh*t hahaha
sick
Old Jan 8, 2014 | 03:40 AM
seelback's Avatar
great simple setup done right and the results show. love the exhaust and intake. car is all around solid, good job!!!
coontech
27
Sep 10, 2018 06:49 AM
ej1_civic
47
Dec 27, 2016 10:13 PM
lohatch
84
Apr 7, 2013 12:00 AM
simplejackk
May 9, 2012 06:32 PM
