ABS Code 13, wheel speed sensor F-L error ?
Old Dec 26, 2013 | 02:48 AM
Progen's Avatar
Default ABS Code 13, wheel speed sensor F-L error ?
ABS light was on, so did the self diagnostic check.. At first came up code 13 and 61 (wheel speed sensor front left open circuit) and (ignition voltage).
Cleared the codes and code 61 gone away but the 13 is still there.. What am I supposed to check/look for now I have this? where is the wheel speed sensor and how would I know its not working or whatever>?
Old Dec 26, 2013 | 09:00 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: ABS Code 13, wheel speed sensor F-L error ?
they wear out.
they r there to jus light up n make u spend $.
replace speed sensor. its by the caliper
Old Dec 27, 2013 | 02:26 AM
Progen's Avatar
Originally Posted by rick_rabies
they wear out.
Will unplug it first I guess and clean it with a bit of maf cleaner and plug it back in see what happens. if not I'll replace it, can't be much $.
am I right in saying could also be something to do with the abs ring on the drive shaft?
2gnarly
Mar 1, 2009 03:24 PM
jojo69
Apr 27, 2006 04:57 AM
Devo94ac
Jan 31, 2006 01:20 PM
