compatibility question
At the junkyard. Saw a b series head and I assume clutch *exedy in the trunk of another car. I hid it somewhere else. Will it fit my d series? And out of left field will a b7 rocker arm assembly fit other d series like a6?
Si's and HF's were MPFI from factory, hence why you use their dizzy. DPFI and MPFI dizzy's are different.
You use the ecu corresponding to your engine, you can make any engine MPFI by using a resistor box, etc.... there's plenty of write's go research. haha
well to clear up that sentence. when i research the mpfi conversion even in the faqs it only mentions using Si components but it never says that Si components are my only option and i have to use one those.
It says Si components because that's what you "have" to use. You could also use componants from any other MPFI vehicle that is from the same era. I.E. DA resistor box (i believe they had one at least). Just don't make it harder than it is, follow what it says and you're golden.
vladd
Jul 13, 2003 11:07 AM
