2004 Honda CRV washer fluid tank
2004 shouldn't require removal of front bumper.
1. Remove the one bolt that holds the filler neck portion of the washer reservoir, then separate and slide the filler neck portion off the reservoir.
2. Remove the left inner fender.
3. Disconnect the 2P connectors and washer tubes.
4. Remove the one bolt that hold the reservoir, then slide the reservoir off a bracket and out.
Thanks for the direction, tech8. I really appreciate it. I will get some of the new plastic screw/anchors to hold the inner fender in when I go back to reinstall. It was very nice of you to respond and point out. Thanks, Jim
hondamonkey
22
Apr 19, 2006 09:49 AM
Black HB
Aug 16, 2003 07:50 PM
