Transmission & Drivetrain Gearboxes, Differentials, Clutches
Is my transmission done for?
Old Dec 25, 2013 | 02:21 AM
lukasmccracken's Avatar
Default Is my transmission done for?
So the other day I was driving and started hearing a whirring sound. I thought about the throw out bearing and decided I would change it and would just get home. However I started not being able to get into gears. I then went to pull over and all of a sudden i heard a thud sound and my car could no longer drive. I could start just not move. It almost seems as though the gear is locked up I also had to hold in the clutch while it was in neutral to even roll. I couldn't even roll while in first and pushing clutch in.
I jacked the car up and drained the tranny fluid... however no fluid came out. I had no idea I had a leak in the tranny but no metal pieces are floating in there. So I hope that I lucked out there (probably not).
I have a farely fresh SiR B16 transmission on a B18 block(If that matters)
So I guess my question is has this ever happened to anyone and what needed to be done to fix it? Will I have to replace my tranny? or will I need a new clutch kit? input shaft? Please any help is qreatly appreciated.
Old Dec 25, 2013 | 01:10 PM
94EG8's Avatar
Seagull Management
Default Re: Is my transmission done for?
If no fluid came out that's not a good sign. Pull the trans, pull it apart and see what happened.
Old Dec 27, 2013 | 07:30 AM
lzylst's Avatar
The internals of the transmission have probably melted. I have seen one instance where 5th gear counter & main shaft were melted smooth. At this point I'd say the case is about the only thing that is salvageable.
Old Dec 29, 2013 | 10:33 PM
This was almost exactly what happened, I can't even believe it, I just swapped this engine/ tranny this summer. I guess lesson learned haha, so if you know of any b series trannies let me know!
Old Dec 30, 2013 | 08:29 AM
sportsman1539's Avatar
I have a ys1 b17 short geared tranny Ill sell ya. It's been rebuilt with new synchros, springs, countershaft bearing, and new 3/4 sleeve all from gearspeed. About 2000 miles on the rebuild. Only reason Im selling it is because I came across another one and rebuilt it but with an ls 5th and put it in my car.
Same gearing as an ITR tranny but in cable form.
88 EF Hatch
Oct 4, 2009 05:27 PM
JDM3STAGEVTEC
Dec 23, 2008 12:10 PM
jdmstyler
Oct 22, 2007 10:36 AM
Oz
Aug 9, 2004 08:20 PM
ILOVEGIRLS
Feb 25, 2002 04:10 PM
