battery draining
Old Dec 24, 2013 | 10:00 PM
niceprelude's Avatar
Default battery draining
Please help! i tested the voltage that reads 12.41v with the car engine shut off and with the car engine running it reads 12.05v and it keeps dropping by 1 every 20 seconds until the car is dead .also the battery charging light comes on .so what might be the problems?
Old Dec 25, 2013 | 04:37 AM
Default Re: battery draining
yes,still waiting for answer
Old Dec 25, 2013 | 05:15 AM
goldsy's Avatar
Assuming your battery is good (which is the first thing to check), you have a parasitic drain somewhere.
Close all the doors and take the key out of the ignition,
Best way I have found to find a parasitic drain it to take a multimeter and set it to amps.
Disconnect the neg battery cable. Put one end of the multimeter on the neg battery cable and the other end on the neg battery post.
If you get a reading of more then 50ma then you have a parasitic draw.
Rig the multimeter up so that it stays connected to the battery and you don't have to hold it because you're gonna start pulling fuses.
Start removing fuses one at a time (starting with the underhood fuse box). Take one out, read the multimeter put fuse back in, etc, reading the meter with every fuse until you see the amps drop. A drop will indicate that the draw is coming from that circuit.
Important step:
Disconnect the multimeter before opening the door to check the dash fuse box. You don't want to fry the meter when the dome light comes on. Once the door is open, rig up something to hold the door switch in so the dome light doesn't come on. Hook the multimeter back up and continue the fuse pulling process with the under dash fuses.
Once you find the amp drop, you've narrowed down the circuit that is drawing the power. A wiring diagram at this point will be very helpful so you can determine which components are on that circuit and can then narrow down your problem.
Old Dec 25, 2013 | 05:19 AM
HondaPartsHero's Avatar
Technical Hero
Alternator, take it off and to a parts store and have it tested
Old Dec 25, 2013 | 05:20 AM
the battery is new from autozone
Old Dec 25, 2013 | 05:25 AM
the car is draining battery while running
Old Dec 25, 2013 | 05:26 AM
Important step:
its draining while car is running, not sitting there overnight
Old Dec 25, 2013 | 05:29 AM
goldsy's Avatar
Your wording wasn't quite specific enough........ And I can't read apparently.
You're alternator isn't charging properly. If you're losing a full volt every 20 minutes its probably time to replace it.
Old Dec 25, 2013 | 05:50 AM
Lizardslap's Avatar
do that theirs a very high chance its the alternator I did a parasitic draw on my car that did exactly that except I disconnected the alternator last and could have saved my self the trouble by disconnecting it first
Old Dec 25, 2013 | 07:47 AM
carlos8's Avatar
Most likely your alternator it's gone (12.05v engine running).
Take it to test.
Old Dec 25, 2013 | 07:55 AM
afnan's Avatar
Check for the connection with Alternator and Positive Terminal. Check continuity and voltage drop test on Alternator Ground with Body Ground.
There should not be drop more than 0.5V
Old Dec 25, 2013 | 07:58 AM
also the battery light come on
Old Dec 25, 2013 | 08:31 AM
jmosley89's Avatar
where can i find a diagram for wiring for honda civic?
Old Dec 25, 2013 | 09:34 AM
95Sedan's Avatar
does the battery die when the car is off? or hold voltage?
Old Dec 25, 2013 | 10:47 AM
it holds charge 12.41v. than when start the engine,it reads 12.01 than drop by 1 every few seconds until dead
Old Dec 25, 2013 | 04:33 PM
95Sedan's Avatar
i mean if you leave it sit for a day what does it do? if the battery holds when the car is off my opinion you have a bad alternator or a bad alternator ground somewhere, which sucks because they are expensive.
Old Dec 25, 2013 | 07:11 PM
if it sit there whole day,it would hold the charge.it losses charge when starting it
Old Dec 26, 2013 | 11:39 AM
95Sedan's Avatar
have the alt load tested if you can make it to autozone, Check the alt ground. check the alt power wire make sure it's not loose.
niceprelude
Feb 26, 2017 08:03 PM
UrVtecIsLoud
Dec 7, 2008 12:09 PM
LSracing94
Aug 19, 2007 08:07 AM
samp
Dec 4, 2006 11:05 AM
wahee
Jun 2, 2006 02:06 PM
