Camshaft Seal question
Old Dec 24, 2013 | 07:52 PM
TravisCadello's Avatar
Default Camshaft Seal question
We just put a new head on this 98 F23A1 and it is throwing oil all over the timing belt im almost positive my brother didnt place the cam seal correctly we drove it 20miles home and all is good except the leak.
My question is, is it possible to fix this with out removing timing belt AGAIN? Its differently leaking behind the CAM Gear.
Old Dec 24, 2013 | 08:51 PM
holmesnmanny's Avatar
Default Re: Camshaft Seal question
Nope, you gotta pull the sprocket to get to the seal. That means removing the belt.
If you used an aftermarket seal, you have to put some grease on the inner lip of the seal for it to break in properly, or it got caught turned as he pressed it on, which is a result of not putting grease on the lip as well.
Old Dec 25, 2013 | 10:40 AM
ok cool, thanks. im gonna try and do it all without removing harmonic balancer.
Old Dec 25, 2013 | 01:11 PM
djkurious's Avatar
Actually there is a way to replace it w/o removing the entire timing belt. Nus_dogg actually talked about it in one of his post. It worked for me. Remove the covers, mark the belt and the cam gear with a marker and remove the belt but make sure it doesn't move off the other gears. Remove the cam gear and seal and replace the seal at the same mark. Before starting this make sure you are at TDC just in case.
Old Dec 25, 2013 | 05:33 PM
yeah, alls i did was set motor at TDC and removed only upper cover, removed belt and now waiting for tomorrow cause autozone closed Christmas day lol.
I got a question, Is their one single cam seal or is it a two piece seal? i removed one looked like outter and another inside head a little.
Old Dec 25, 2013 | 07:06 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Single seal.
Old Dec 25, 2013 | 11:33 PM
I kinda figured he was talking about removing the belt from the sprocket.
rough_draft
Mar 29, 2005 04:52 AM
RCautoworks
25
Aug 15, 2004 09:17 PM
zueke
Nov 28, 2003 08:38 PM
