B16A Swap Won't Start
Old Dec 24, 2013 | 07:42 PM
Qxio's Avatar
Default B16A Swap Won't Start
I just swapped in a B16A with 35k miles from HMotors in my 1998 Civic EX. The engine cranks, but does not start. Tried the B16A ECU as well as my old Y8 ECU. I can hear the fuel pump prime and have the harness properly connected. When turning over it occasionally sputters like it's trying to start but that's it. Any ideas?
Old Dec 24, 2013 | 07:50 PM
B_Swapped93's Avatar
Default Re: B16A Swap Won't Start
check weather or not you're missing spark or fuel at least it cranks lol simple to narrow down from here. also just double check mechanical timing you never know....
Old Dec 24, 2013 | 07:55 PM
Qxio's Avatar
Will do. Also, before it wouldn't crank because I forgot to ground the valve cover/engine, do I also have to ground the transmission or anything else?
Old Dec 24, 2013 | 08:03 PM
NotARaCist's Avatar
I never narc'd on nobody!
yes but if those were bad it wouldn't even crank at all.
Old Dec 24, 2013 | 08:12 PM
Qxio's Avatar
Originally Posted by NotARacist
I have the battery ground, headlight harness ground, and "engine ground A".
Old Dec 24, 2013 | 08:14 PM
Qxio's Avatar
Alright. I have spark; to check fuel do I just remove the four bolts on the fuel rail to pull the rail and injectors?
Old Dec 24, 2013 | 09:02 PM
just remove the spark plugs and look at/smell them if they're wet you're getting fuel.
Old Dec 25, 2013 | 08:58 AM
PaleAleS2k's Avatar
Also, check the ground on your thermostat. If you pull the rail and injectors back have someone hold the injectors tight against the fuel rail. If you don't the fuel pressure from the rail will pop one or two of your injectors off.
Old Dec 25, 2013 | 10:00 AM
hardcore97's Avatar
if it sounds like its attempting to start and you are getting fuel and spark check your mechanical timing.
Old Dec 25, 2013 | 10:40 AM
civicb1812345's Avatar
check the plug wires and that they are in the right order.
Old Dec 25, 2013 | 04:00 PM
instrument's Avatar
That's what it sounds like to me
Old Dec 25, 2013 | 04:32 PM
allmotoralladay's Avatar
check firing order
Old Dec 25, 2013 | 11:37 PM
aavtec's Avatar
Not something common but seen it happen before, the distributor thing that goes into the camshaft needs to be fliped around 180°
Old Dec 26, 2013 | 02:14 PM
Qxio's Avatar
I got it running. There must have just been a lot of air in the fuel rail/fuel line. She finally started with perfect idle and no leaks. First swap I've done.
Old Dec 26, 2013 | 02:29 PM
andre3wap's Avatar
Good job man
CMunsterman
20
Feb 19, 2022 01:11 PM
Bagged_em1
Oct 27, 2016 04:43 PM
92 white eg
Sep 27, 2006 08:55 AM
mrduque
Jun 20, 2002 05:05 PM
