can I swap blocks?
Old Dec 24, 2013 | 09:33 AM
89ED's Avatar
Default can I swap blocks?
I gotta a b2 in the car and picked up a a6 head and trans this week. Just wondering if I could use a relatively "young" d16 block from the junk yard and mat the a6 head and trans to it.
Old Dec 24, 2013 | 11:41 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: can I swap blocks?
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-d16z6-block-d16a6-head-2754616/
^That's from the FAQ by the way.
And simply put, you can interchange most heads/blocks/transmissions/manifolds with relative ease between all 88-00 D-Series SOHC engines.
Old Dec 24, 2013 | 05:31 PM
89ED's Avatar
Thanks. I ddint research sorry.
Old Dec 24, 2013 | 06:01 PM
89ED's Avatar
And I have read that thread before
Old Dec 24, 2013 | 06:33 PM
24TEN's Avatar
PHANTOM MENACE
No worries. Using a Y7/8 block should be pretty close to that write up.
Old Dec 24, 2013 | 06:46 PM
89ED's Avatar
In that thread witch of the two options do prefer or would have preferred. Using the pm6 or shaving the head?
Old Dec 24, 2013 | 07:08 PM
89ED's Avatar
Or thin metal head gasket
Old Dec 25, 2013 | 11:34 AM
89ED's Avatar
Old Dec 25, 2013 | 02:18 PM
24TEN's Avatar
PHANTOM MENACE
My choice was circumstantial. Ideally it would've been nice to use the correct pistons because that would yield the correct compression and nothing permanent would've been done (you can't unshave the head). Of course using new pistons leads to more work so keep that in mind.
mon.jar94
May 20, 2013 07:42 PM
K20teggg95
Oct 22, 2011 10:41 AM
mixmastermatt
Jan 27, 2007 08:49 AM
WagonKore
Dec 3, 2006 12:39 PM
biggnubbs
Nov 2, 2005 09:38 AM
