what will the best b series build be with all stock parts NA
Old Dec 21, 2013 | 04:52 PM
jawnewbe2's Avatar
Default what will the best b series build be with all stock parts NA
on so i have a full jdm b16a and i have a b18b1 full motor block is cracked (so cant use block). have another b18b1 full motor but motor mount bracket snapped off. i can get a gsr block but not the pistons or i could get a ls block that has no problems and do an lsv. but here is my real question what stock parts should i use b16 pistons and head and use the ls block and rods and crank i would like to know what parts would be the absolute best for what i have the rest will be parted out
Old Dec 21, 2013 | 11:27 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: what will the best b series build be with all stock parts NA
What is with the term best being so freely used here on ht???we don't know what is best for you because we don't know you! You failed to state you purpose of this motor. If you have a complete b16 than use that.
Old Dec 21, 2013 | 11:48 PM
jawnewbe2's Avatar
ok best as in NA build to go into an integra the reason i dont want to use the b16 anymore is because it is not anywhere as powerful as i would like it to be and i figured while i had spare parts laying around start to build it over the winter gives me something to do over the winter because i am laid off till march. i know in order to build the motor to be really powerful i need to get aftermarket parts but i have je pistons in the b16 and forged rods i have no clue what my compression is right now though and so i am thinking stock parts till i get new pistons that i know the specs on it
Old Dec 22, 2013 | 07:03 AM
F22Master's Avatar
B20 Vtec.
Stock B20 block (with ARP rod bolts)
Stock vtec head
GSR, ITR, or CTR cams
Good header (rmf, hytech, toda, etc.)
68mm TB
Old Dec 22, 2013 | 04:20 PM
EFvtec Yo!'s Avatar
Originally Posted by F22Master
B20 Vtec.
Stock vtec head
68mm TB
^^^Agreed. Simple and economical setup and you will be more than happy. Buddy of mine has this setup and the power will really surprise you for how basic the setup is and its been running strong for years.
Old Dec 22, 2013 | 06:23 PM
jawnewbe2's Avatar
ok now with that should i get a tunned ecu and intake manifold
Old Dec 22, 2013 | 10:27 PM
jawnewbe2's Avatar
ok cool beans i will look for a b20 block and now what injector size should i use should i use b18b injectors or b16a injectors
Old Dec 23, 2013 | 04:10 PM
EF9_TryMe's Avatar
If you want to make more power, Yes.
The injector size is the same.
Old Dec 24, 2013 | 09:28 AM
F22Master's Avatar
You need to get a chipped ECU, and then get it tuned by a professional tuner for YOUR engine. Not a basemap, not a guess, not some **** you got off ebay.
And all D and B series injectors are the same size.
Old Dec 26, 2013 | 02:19 PM
93egSLEEPER's Avatar
Close but not quite. Some of the D-series injectors were smaller. 96-98 D16Y7 injector if I remember right. They were 190's if I remember right. Those will not run a B20 properly
that1guy253
K Series
Nov 6, 2013 05:21 PM
kxrider
Aug 13, 2011 07:51 PM
trrbl1bmx
Feb 23, 2006 07:26 PM
Wink1100
10
Dec 24, 2003 06:07 AM
tylerdurden
Sep 8, 2002 10:31 AM
