K20/K24 Kswap
Motor was in my RHD Eh2 I never got to finish the project ended up buying another car.
So motor is for sale
No trades
No low *****
$4600
K24/K20
K24 block re done
K20z3 Si head
New head gasket
Ngk spark plugs
Arias 12.5 pistons
06 type s cams
Rsx base trans no grinds or pop outs
Stage2 clutch
Twostep Motorsport race header
BDL fuel rail
Black fittings
Black steel braided fuel lines
Tucked fuel filter
Rc 630 injector
New obd1 injector clips
Ktuned radiator hoses
Mishimoto fan switch
RBC intake manifold
Ktuned fuel pressure regulator
06 Rsx type S oil pump new
06 Rsx type S oil pan
Jorgie built tucked harness
New axles
Stock shifter box and cables
New oem cps sensor
Egr block off
No trades
No low *****
$4600
K24/K20
K24 block re done
K20z3 Si head
New head gasket
Ngk spark plugs
Arias 12.5 pistons
06 type s cams
Stage2 clutch
BDL fuel rail
Black fittings
Tucked fuel filter
Rc 630 injector
RBC intake manifold
New axles
New oem cps sensor
Egr block off
