running resistor box with high impedance injectors
Old Dec 21, 2013 | 06:42 AM
two81's's Avatar
Default running resistor box with high impedance injectors
So, as the title says. My car has high impedance injectors and still has the resistor box plugged in. Can find an answer to the question. Can't find this exact question either.
My car is running lean according to emission test. Wondering if this is the cause.
Old Dec 21, 2013 | 11:29 AM
two81's's Avatar
Default Re: running resistor box with high impedance injectors
Sorry guys, I'm impatient. Anybody? ?
Old Dec 23, 2013 | 10:52 AM
crex23's Avatar
I've always heard if you run a resistor box and high impedance injectors, it will fry the injector drivers in the ecu. I've not ever seen this personally. I have high impedance injectors in my obd0 mpfi swap, but there is a dead end plug that is plugged in where the resistor box would normally go that runs all the wires together.
Old Dec 23, 2013 | 12:44 PM
sd619jef9's Avatar
I am going through the same **** on my car and from what I am being told is that you need to remove the resistor box and jump the cables to a 12v source so they run at 12v instead of 4 i believe it is
Old Dec 24, 2013 | 04:36 AM
Mad Fab Lab's Avatar
Resistor box + high imp injectors is not correct, bypass the resistor box or run low imp injectors. Since you already know you have this wrong and it is related to your problem fix this first.
808DB1
Mar 28, 2008 01:33 PM
boosted96teg
Mar 15, 2008 06:35 AM
deucedeuceEK
Oct 30, 2007 04:35 PM
MysteryWagon
Jun 17, 2005 04:16 AM
dc2pffsssttt
Apr 14, 2004 08:04 AM
