weathered window rubbers
Old Dec 20, 2013 | 06:55 PM
dc296TypeR's Avatar
Default weathered window rubbers
Would like to restore my rear window rubbers.They have become quite weathered,any suggestions or is there any place that sells them. Acura has discontinued them in Canada.Seems like you get the complete window assembly ,Also do the USDM ones say Acura or Honda.
Old Dec 20, 2013 | 07:10 PM
lazlong's Avatar
Default Re: weathered window rubbers
They would say Acura. Google "Acura OEM parts" and pick one of the online dealers.
Old Dec 20, 2013 | 07:55 PM
itr#1334's Avatar
No parts say Acura.
Old Dec 20, 2013 | 08:29 PM
dc296TypeR's Avatar
That's what I thought as all Integras were made in Japan.
Old Dec 21, 2013 | 04:21 AM
lazlong's Avatar
Originally Posted by itr#1334
No parts say Acura.
Not 100% correct. Right off the top of my head: wheels, seats, airbags/airbag covers, bumpers and badges
I mis-spoke. If the original part says Acura the OEM replacement part will say Acura.
Old Dec 23, 2013 | 06:43 AM
ekcoupeh22's Avatar
you cant get rear window rubbers.. they come on the glass at about $150 a side. you can mask off the car scuff them good and spray them with trim paint.
Old Dec 23, 2013 | 05:28 PM
dc296TypeR's Avatar
Thanks for the info.I will try to redo them in the Spring.
Old Dec 23, 2013 | 07:29 PM
safedriver's Avatar
You can use a detail product called ClearKote Vanilla Moose Wax Hand Glaze.
clearkote dot com
You rub it on and you'll remove the dried black rubber. Let it dry and rub it off. You will need to repeat a few times, to get as much of the dried rubber off, as you can.
I did mine 3 times and now regularly once every month.
Old Dec 26, 2013 | 05:20 AM
98ITRAgain's Avatar
clearkote dot com
Cool thanks for the info. Mine are in bad shape too. I'll give it a shot.
Old Dec 31, 2013 | 10:51 AM
dc4teg95's Avatar
What I did on mine was tape them off and used a red scotch pad from auto paint supply store and wetsanded them with simple green and then went over with a real fine sand paper. From there you can either use duplicolor flexible bumper paint as it is made to adhere to thermoplastic rubber or you can use a product like back to black if you choose not to paint them.
TL_chick_08
Acura TL, RL & ZDX
Aug 18, 2008 10:39 AM
Atlas
Aug 26, 2004 06:46 AM
PatrickGSR94
Mar 28, 2003 02:49 PM
lilcasino
Sep 24, 2002 08:22 AM
90integraGS
Oct 4, 2001 09:59 AM
