think someone switched the springs around...
Old Dec 20, 2013 | 02:38 PM
civicb1812345's Avatar
Default think someone switched the springs around...
ok so i noticed on my civic the other day that it has struts and springs, front is lowered quite a bit back is raised higher than stock, they both say eibach on them and the back is progessive, is there any way the P.O switched them around on accident? would they still fit?
Old Dec 20, 2013 | 03:19 PM
instrument's Avatar
Default Re: think someone switched the springs around...
yes they could
Old Dec 20, 2013 | 03:31 PM
B_Swapped93's Avatar
look at them it will 9 times out of ten say F or R on them have a look.
Old Dec 20, 2013 | 07:12 PM
waynesumner's Avatar
aren't rear springs taller than front to? on my eibach GC they are anyway idk the rates either though.
Old Dec 20, 2013 | 07:24 PM
something like that I haven't used a separate spring/shock combo on any of my cars just full body coilovers. I'm sure somebody can confirm iirc the rears are shorter.
Old Dec 20, 2013 | 07:35 PM
yes if i jack the car up all the way the front spings can move about a 1/4in up and down and are not tight, rear suspension is stiff as hell and with a 205/50/15 tire i have about 3-4inches of wheels gap. and the backs are a lot taller and progressive.
Old Dec 20, 2013 | 07:43 PM
Good change they are messed up then swap them around and see, it's a pita but at least you won't blow your fronts from the spring being too short thus causing the shock to bottom out all the time.
Old Dec 20, 2013 | 07:56 PM
true worst comes to worse it has tokico blue struts so ill get some cheap springs to ride for awhile
23LX23
Suspension & Brakes
Jun 18, 2011 11:52 AM
vinuneuro
Suspension & Brakes
Oct 17, 2007 11:25 AM
91DA
Apr 30, 2005 11:39 AM
garados
Jan 31, 2002 06:28 PM
owen_the_soyboy
Jun 29, 2001 12:43 PM
