AEM EMS V1
I recently purchased an AEM V1 for my 01 GSR. its serial #1001-0045, I already have the jumper harness for it to mate with the EMS. My issue is when I load up the stock cal. map the car wont start. Ive input everything in as far Inj, tps, map, ect. and still no start. every once in a while it would attempt to start then die. Does anyone have a decent base map for a stock GSR?
The vehicle is in working order, currently running on a P28 and it is my daily. Car runs flawless. Im just trying to get this AEM thing figured out and then get it to a tuner once the other motor and turbo go on. Thank you.
I pay less then what I would have bought an s300 if that helps. Not really interested in the V2. The setup im trying to get started is for a completely stock GSR, all it has is a short ram intake. Thank you for the reply.
Sync timing, rinse, repeat.
Best way - turn injectors off, have friend crank car over while you hold timing light & watch timing marks. Once sync'd, turn injectors back on and fire it up.
