Transmission & Drivetrain Gearboxes, Differentials, Clutches
B series trans mounts into eg
Old Dec 19, 2013 | 11:24 AM
Jtmvtec's Avatar
Default B series trans mounts into eg/my ht INTRO
Alright I've been on Honda tech for about 3 years sourcing info without having to make an account and ask a question. Today is different. If got an eg hatch b20v with a b16 cable trans. I blew the trans last week and got a hydro ls for 30$ so I want to put that in. Pulled the b16 new stage 3 exedy clutch disk new flywheel and blah blah. My mounts aren't working. I've got the trans bolted up but the t bracket mount isn't lining up and the trans mount is defiantly not lining up. I've heard a few different mount stories but no one seems clear which mounts I actually need. Right now it's the 3 post b16 mount and that's not gonna work. Anybody have a link to a thread I've missed or can tell me exactly which mount and t bracket I need? Thanks in advance
Old Dec 19, 2013 | 01:58 PM
94EG8's Avatar
Seagull Management
Default Re: B series trans mounts into eg
You need a rear T-bracket from a '94 - '01 Integra 5 speed and mounts from a '92 - '95 civic or '94 - '01 integra 5 speed (both work, the integra rear mount is stronger though, IIRC the upper mount is exactly the same)
If the civic happened to be an automatic originally (bracket on the passenger's side will point up at about a 45° angle) you'll need an auto to manual swap mount or you'll need to drill the spot welds out of the bracket welded the passenger's side frame rail and replace it with the manual version.
Old Dec 21, 2013 | 02:36 PM
Jtmvtec's Avatar
Sorry for the late replay but thanks for the info. I figured it out I didn't know mounts were different from cable to hydro trans, has port trans mount and dc t mount and it's good to go. Thanks man
burnoutboy
Aug 30, 2013 02:05 PM
2004es2
58
Jan 17, 2008 11:46 PM
418whpturboD
Jan 3, 2008 11:45 AM
NathanielH
Aug 19, 2006 04:46 PM
RICE POLICE SIP
Jan 7, 2005 03:09 PM
