Endlinks
Old Oct 28, 2002 | 07:17 AM
CXHatchback's Avatar
Default Endlinks
What are they? I've been reading as much as I can about installing my rear swaybar, but can't figure out what they are. Who know? Pics appreciated...
Old Oct 28, 2002 | 07:28 AM
g_man80's Avatar
Default Re: Endlinks (CXHatchback)
Here's a picture of a rear swaybar installed. The endlinks are at the outermost part of the bar and connect it to the LCA. Usually a combination of bushings and washers held together by a bolt and locknut.
G
Old Oct 28, 2002 | 08:01 AM
Default Re: Endlinks (g_man80)
Thanks man, I think they are what I thought they were. I have an oem rear bar off a civic sedan that I want to put on but I can't see where it would even bolt up, not even with the original lcas.
Old Oct 28, 2002 | 08:18 AM
g_man80's Avatar
Unfotunately, because the cx didn't come with a factory swaybar your lower control arms wont have the mounting hole for the oem bar you have. You'll need the LCAs off the same car with the mounting hole if you want it to work. The pictured bar is a suspension tech aftermarket bar. This kit comes with adaption brackets which mount at the bottom of the shock on the LCA.
G
Old Oct 28, 2002 | 09:24 AM
Yeah well that's what I meant, I didn't see where they would mount even on the lcas that came with it. Now if I don't have the bolts to bolt them to the lcas, can I just go buy some?
Old Oct 28, 2002 | 09:54 AM
racecarpete's Avatar
it's not bolts that you are lacking but bolt holes on your rear lca's, you will have to pick up a set of lca's from an integra, they go for about 40 bucks.
Old Oct 28, 2002 | 10:09 AM
Default Re: Endlinks (SilverCivic2k)
ok, once again. I have the the lcas/rear sway bar/trailing arm assembly/shock/spring setup from a 95 ex sedan, so I have the lcas that came with holes for mounting the sway bar, they just don't seem to line up and I haven't found pics of an oem sway bar mounted yet.
Old Oct 28, 2002 | 11:24 AM
g_man80's Avatar
Here's a pic from a 94+ integra which shares the same LCA setup as the eg's if I'm not mistaken. It's hard to see the endlink setup, but I hope it helps. I'll keep looking.
G
Old Oct 28, 2002 | 11:39 AM
Thanks that helped a little bit. I think hybrid honda has pics but none of them really shows the endlink setup which is what i want the most.
ian1006
Honda CR-V & Element
Jan 25, 2014 03:41 PM
Damon Reeves
Suspension & Brakes
Jul 19, 2006 09:20 PM
d16rice
Suspension & Brakes
Jun 4, 2005 05:38 AM
GraphiteAccord
Feb 10, 2004 07:44 PM
Kid1320
84
Mar 12, 2003 07:01 AM
