how to install SRR rear LCA, tie bar and rear sway bar
install the whole rear lower suspension from SRR today/tonight on my Si coupe..... the rear 19mm sway bar is a noticeable difference. cant notice anything with the LCA just bling factor i guess. the rear tiebar works with the sway bar's stiffness i guess. only got to go around the block once tonight. well pics below and some instructions
#1 remove rear hub assembly bolt
#2 remove lower shock/strut bolt
#3 remove sway bar bolt from LCA
#4 remove bolt from tiebar/ chassis
#4 and #5 are the upper sway bar mounts remove those also
this is the passenger side with all the bolts take off. should look like this
should look like this all stripped
the arrows show to remove the mount pieces for the swaybar as the SRR tie bar assembly has a built in mount piece for the sway bar.
when installing the rear LCA just reverse the process. bolt on the chassis, lower shock/strut bolt and rear hub assembly bolt.
for the SRR lower tie bar it is one whole piece with built in sway bar mounts. when installing this piece you will need to unbolt the LCA from the chassis and place the rear tie bar in its place and bolt it back in. where the stock sway bar mounts were, reuse those bolts and place the bolts in its proper place.
then mount the sway bar in its left over bolt holes and......
whaala SRR rear suspension installed
[Modified by Kid1320, 3:38 AM 3/9/2003]
Re: how to install SRR rear LCA, tie bar and rear sway bar (93H22HB)
thanks i dont know about the color combo though, that's the only thing. would you guys powder coat the blue parts black?
Re: how to install SRR rear LCA, tie bar and rear sway bar (Kid1320)
<--just got srr goodies himself (like 4.9 final drive )
if anybody wants SRR products, then here on h-t you can IM exospeedAMcrx. his aim name is the same. He's Wil from http://www.exospeed.com he's THE man for the srr shizzle.
[Modified by JaeOne3345, 4:11 AM 3/9/2003]
Re: how to install SRR rear LCA, tie bar and rear sway bar (sean)
I'm not 100%, but I think they are on upside down.
You'll gain travel if you flip them over.
The shock mounting bolt is offset.
Edit: they = LCAs
[Modified by Eee Pee, 10:30 AM 3/9/2003]
Edit: they = LCAs
Re: how to install SRR rear LCA, tie bar and rear sway bar (Migs)
Bout ****** time Kid1320 contributes instead of just picture whoring.
EDIT: i would powedercoat thos peices man, you are asking to get jacked.
[Modified by euclid, 11:44 AM 3/9/2003]
Re: how to install SRR rear LCA, tie bar and rear sway bar (euclid)
http://www.invoauto.co.uk/images/Pro...05pc%20kit.jpg i think the kid got it wrong but how come srr logo is up
[Modified by seek167, 10:50 AM 3/9/2003]
Former Moderator
Re: how to install SRR rear LCA, tie bar and rear sway bar (1)
I was going to say the same thing about the LCAs being upside down.
Other than that I think it was a great write-up - thanks for the good work kid1320!
Re: how to install SRR rear LCA, tie bar and rear sway bar (B18C5-EH2)
Looks good. I just wish I could afford stuff like that. It also looks like a lego set or the like from when I was younger.
Bwahahhah thats some funny stuff right there
A how to right up thats wrong..........
But yeah those are still nice
Looks similar to my setup, but i paid $30 for mine... the guy i bought it from was like its funky, and doesn't look right on my EX. (He didn't have a swaybar). Works great with my Mugen 22mm Swaybar.
Re: how to install SRR rear LCA, tie bar and rear sway bar (ScrapinSi)
Nevermind, I looked at them again, he does have them on upside down. OOPS!!
[Modified by 93H22HB, 4:45 PM 3/9/2003]
I urge everyone to be carefull with those lower LCA bolts. If your car is more then a few years old they may be froze up really tight.
Drench them in pentrant spray a day before removal, and/or heat the **** out of them when finally taking them out.
They are easy to break..I know from experience.
Kid1320, where did you get the SRR swaybar, and tiebar combination?
wait, im confused, where do these go????
agreed. those just tell people to jack your car. *if* it was my suspension, id powder coat EVERYTHING black, but thats just me
[QUOTE]Bout ****** time Kid1320 contributes instead of just picture whoring.
