turbo options
so i just bought a lan-evo. i know this is for Hondas only but maybe a tuner will see this post and help out.
the car has two different tunes. but the previous owner doesnt know which is which. is there a way i can just plug it into a tuners computer to find out the rev limit and boost limit on each tune?
Head over to the engine management Forum. The best thing to do is GO to the tuner that deals with the software interface you're using and let he/she determine which is which. A competent tuner won't let you use their computer to "nose around" to find out which file is which.
Good luck.
Good luck.
**Moved to Engine Management/Tuning forum**
I would have edited the title, but moved it before trying to change it...i have no access in this forum. A good title makes a big difference in whether or not you get any help.
Any competent DSM tuner should be able to read them for you. They may or may not charge you a hook up fee.... depends on the tuner.
Do you know what EMS or software that was used to tune the car? With the appropriate hardware hook up to your EMS and the software loaded you might be able to read it yourself. The previous owner should at least know that.
T Rick
May 2, 2007 01:32 PM
