Transmission & Drivetrain Gearboxes, Differentials, Clutches
What are my options?
Old Dec 16, 2013 | 02:54 PM
Sebba's Avatar
Default What are my options?
I have a JDM H22a swapped EK with a P2A5, and I have third and fifth gear syncro failure.
I'm going to be changing the transmission, but I want to know what my options are before I purchase a replacement.
My questions are:
1) Can I bolt up any H22 transmission? (if not, are there any specific transmission codes that will NOT work?)
2) Will I have to change anything else to accommodate the replacement transmission?
3) What are the best options, for both open diff transmissions and LSD, that will bolt up without work?
Thanks in advance!
Old Dec 16, 2013 | 03:25 PM
Sebba's Avatar
Default Re: What are my options?
I need me a guru, someone chime in!
Old Dec 16, 2013 | 06:14 PM
94EG8's Avatar
Seagull Management
You can't use a transmission from an H22A4 due to the ATTS any other H/F transmission will work.
Get the shortest geared transmission you can find and get one with an LSD if at all possible.
Old Dec 16, 2013 | 07:03 PM
Sebba's Avatar
Thanks! That's all I needed to know, budd.
******* LSD trans are uber expensive.
jdmkha
Apr 18, 2010 11:41 PM
uberEFtuner
Feb 9, 2010 06:46 AM
hondafleet82
May 25, 2009 07:01 AM
sk8shorty012
May 31, 2006 11:30 PM
lilbill3554
Oct 21, 2003 05:05 PM
