Check engine Codes
Hi everyone i need some help with my honda i have run ignition ant checking check engine codes i got 7 ,22,41 i got information what that codes meens
7 - TPS - throttle position sensor
22 - VTEC pressure valve
41 - Primary oxygen sensor heater
but dont have any idea how to fix it can some1 share they experience and help my solve this out ,
7 codes i ges its because one of connector are broken
but what can by with 22 and 41 codes pls help my solve this
more times then not if you're getting 41 just replace the 02 as for 22 vtec ps look at the FAQ sticky up top show a flow chart on how to test the it. 7 check the the tps is getting the correct voltage for starters.
it was when i buy this car , i ask about working with Z6 on other forum and one smart guy says that they are very similar and they shoud work . There is one of connector broken who gives 7 error code dont know mabey there is ware start all other errors because now he is no connected
Amorous
Mar 14, 2009 04:47 AM
serious
Apr 6, 2003 06:07 PM
