O-Rings for PGM-FI fuel injectors
i have the PGM-FI Dual point fuel injection. the one with 2 injectors. had a problem with the o ring. removed to check injectors and found they were stretched out and loose. i replaced them with a kit from the local auto parts store about 6 months ago. i put the old ones back in and it running fine. it would be nice to just get the o-rings in a viton or chem resist type. or if anyone knows where to get just the o-rings. i paid $70 bucks for the kit. i just want the o-rings. thanks.
I answered this in your last thead.
22 and 23 are the O-rings that you need 2 of each, one for each injector.
You want just the O-ring? Why not measure it. Or you can try and find it online.
http://www.hondaautomotiveparts.com/...E+BODY+%281%29
020-023 I believe are O-rings. Don't know which you need.
UrMyI3itch
May 2, 2003 12:05 PM
