Noisy water pump - and new...
Old Dec 16, 2013 | 06:00 AM
pityocamptes's Avatar
Default Noisy water pump - and new...
Just got back my Honda from a Honda repair company, and they replaced the previous pump because it was making noise at around idle to 1K rpm's. They indicated that the noise was an overly tight seal? Anyways, they replaced that pump and I noticed that the new pump makes a rarrr noise, hard to describe, at around 1-1.5K rpm's. Other than that, it is quiet. I thought about taking it back, but might just call them to let them know, so that if it gets worse, I can take it back with no issues.
Is there a break in time for pumps? Are some pumps "noisey"? Thanks...
Old Dec 16, 2013 | 07:39 AM
ElectronBlue00's Avatar
Default Re: Noisy water pump - and new...
Do you know if they used OEM or Aftermarket? (Im assuming they used OEM) My assumption is that the water pump should not make any noise. I've done them on my TL, and EM1, with no noise at all.
Are you sure that its coming from the pump itself, and not somewhere else?
raverx3m
Feb 3, 2011 03:15 PM
Luward
Honda CR-V & Element
Nov 27, 2010 12:25 PM
mooploops
Jul 29, 2009 11:42 AM
fireant
May 18, 2008 03:35 PM
Ge-money
Sep 6, 2006 02:55 PM
