99' CH9 wagon idle issue
Old Dec 15, 2013 | 09:40 PM
red_cap's Avatar
Default 99' CH9 wagon idle issue
my 99' wagon, has an H23A DOHC VETC (i live in okinawa), is having issues with keeping a good idle once it has warmed up. while the engine is cold it idles fine, but once its warm it seams to idle to low and at times sut off (happend about 4 times in three months). once i was reving the engine in park and the engine sut off like i turned the key off, wouldnt restart untill i turned the key off and back on. now if i run the A/C it has no issues with idle while driving around. any ideas of what could be causing this? car has 91K kilometers on it and a lot of slow Okinawa speed driving.
Old Dec 16, 2013 | 05:09 AM
ej7attack's Avatar
Default Re: 99' CH9 wagon idle issue
start off checking three things.
air.
fuel.
spark.
your getting all of them but one is dying off. most likely air.
check you idle air control valve, clean if necessary.
check egr ports, clean if necessary.
clean your throttlebody.
im leaning towards dirty iacv.
Old Dec 20, 2013 | 02:49 AM
red_cap's Avatar
i am thinking iac as well. figured i would pop the question before i tear the tb off. this is my first honda, im assuming the iac is located on the tb?
Old Dec 20, 2013 | 06:27 AM
afnan's Avatar
It is back of Air Intake. This may help you https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Old Jan 4, 2014 | 09:51 PM
red_cap's Avatar
so im finally getting around to getting this iacv cleaned, but after looking at the link posted above it seams that my iacv isnt on the back on my intake. is it one of the sensors on the front?
maybe its this on the front?
KimvdLinde
Jun 29, 2013 01:40 PM
v8killaz
Nov 23, 2011 08:19 AM
b20beast83
Aug 7, 2008 04:57 PM
twisted civic
Jul 19, 2008 11:09 AM
BLANCOh22a4
Oct 22, 2007 10:03 AM
