Anyone have complications with e85 and journal bearing turbos?
Old Dec 14, 2013 | 11:21 PM
trunkluv's Avatar
Default Anyone have complications with e85 and journal bearing turbos?
I've heard of a few people blowing seals after switching to e85 with jb turbos..I have recently switched to e85 and looking to buy an other turbo as a backup, trying to confirm if this can happen or not
Old Dec 14, 2013 | 11:32 PM
rudebwoy's Avatar
Default Re: Anyone have complications with e85 and journal bearing turbos?
Nope!
Old Dec 15, 2013 | 02:00 AM
frost_white_ej1's Avatar
ugh! i mean how is that even possible!
Old Dec 15, 2013 | 04:09 AM
ls_on_boost's Avatar
I'm guessing people with catch cans tap to the back of the block letting the moist or watered down oil back In the block just contaminating the oil in the pan and not changing oil I use journal turbos and e85 and never had a problem but I only use the valve cover to the catch can and empty it every so often and change oil often
Old Dec 15, 2013 | 05:02 AM
itspools's Avatar
I would guess its oil contamination from the moisture.
Or they just have a precison journal bearing turbo.
Old Dec 15, 2013 | 05:12 AM
Honda Bull's Avatar
This.
Be sure to maintenance the vehicle how it should be.
Old Dec 15, 2013 | 06:21 AM
luck4rmkc's Avatar
I'm assuming you had the same experience with precision JB turbos as I have. My 6262 was two seasons old and had maybe 500 street miles on it when it started smoking. Sent it back and they advised it was from "oil contamination". My oil never even gets past the color of honey in my car so I'm not sure how that would be the case.
Old Dec 15, 2013 | 08:58 AM
itspools's Avatar
That's a popular one they use, oil contamination. I've seen multiple issues with jb precisions on customer and friends cars. Personally I've used Borg Warner for the past couple of years and when I was on e98 my oil would look like the color of pudding and I've never had an issue with the engine or turbo.
Old Dec 15, 2013 | 09:13 AM
SPOOLINmatt's Avatar
lol ive seen that pudding oil before.
I've never had a problem with my precision turbos on E85.
Old Dec 15, 2013 | 09:15 AM
Twenty47's Avatar
Not rocket science why it could be possible.
Old Dec 15, 2013 | 09:32 AM
lindseyhunt1090's Avatar
get a good oil, don't recirc your catch can back into your motor. change your oil more due to e85 brake down. your good.
Old Dec 15, 2013 | 09:38 AM
x2
Old Dec 15, 2013 | 04:28 PM
trunkluv's Avatar
Yeah ran precision turbos. I have a catch can only running lines out of the head..don't tap into the block?
Old Dec 16, 2013 | 04:37 AM
D-Rob's Avatar
The Precision will die by itself, by no other fault of fuel choice, oil quality, abuse, etc.
Old Dec 16, 2013 | 06:00 AM
MR.johnson's Avatar
i recirculate my oil and it looks new every time i drive it. i do change it alot, no problems with the turbo smoking or blowing seals.
Old Dec 16, 2013 | 12:01 PM
95eggsr66's Avatar
nothing but good running e85 with jb precision
Old Dec 16, 2013 | 04:35 PM
trunkluv's Avatar
Should I tap Into the ports on the back of the block for my catch bcan? Or will it dump oil hard?
Old Dec 17, 2013 | 05:09 PM
$MIKE$'s Avatar
Can any one else validate oil recirculating from catch can using e85 causing turbo failure, or is it common knowledge not to recirculate oil from catch can on e85 applications
Old Dec 17, 2013 | 05:10 PM
$MIKE$'s Avatar
Are u recirculating from a catch can?
Old Dec 17, 2013 | 06:34 PM
trunkluv's Avatar
Should I use the two ports on the back of the block for the catch can or just the head? It's a 6 port can that's capped off
Old Dec 17, 2013 | 06:58 PM
$MIKE$'s Avatar
U can use the two on the back of the motor if the motor is still in the car the far one can be a pain but there's a company that makes. Plug - -10an to the old "black box" hole that's what im am running now as drain back plus two for cover, never heard any trouble about this kind of set up till now.
Old Dec 17, 2013 | 08:24 PM
trunkluv's Avatar
I think the fittings I have came from the acura dealership for the back of the block.
LOGONZOJLS
Sep 1, 2006 09:08 AM
drpepper
Oct 13, 2005 01:31 PM
Pete_SI
Dec 21, 2003 05:00 PM
GruvyTune
Oct 14, 2001 06:09 AM
