track rod snapped
Old Dec 12, 2013 | 08:48 AM
89ED's Avatar
Default track rod snapped
Is there I beefier replacement like from a da or prelude that will work
Old Dec 12, 2013 | 08:51 AM
Freemananana's Avatar
Default Re: track rod snapped
What is a track rod?
Old Dec 12, 2013 | 10:06 AM
Mister Clean's Avatar
Track Rod = tie rod.
Old Dec 12, 2013 | 10:59 AM
Oh. Well shucks!
DOUBLE DANG: I just typed like 2 paragraphs about radius rods. Haha!
Tie Rods basically control your steering. I would get Moog replacements. I am not sure that you can use any other tie rods since it is a steering component. I think you would have to swap the steering rack.
Old Dec 12, 2013 | 01:29 PM
radex7's Avatar
Out of curiosity I looked up those things, including Moog's product, and although I do believe Moog may be making better rubbers and pivot joints for their products, I doubt that casting (or forging?) would be that much "biffier" - if at all. What bugs me is that OP actually managed to snap those. How often do you come across reports about that that drives people to search for better than OEM replacement? Thanks OP for learning opportunity.
Old Dec 12, 2013 | 01:38 PM
F22Master's Avatar
If you REALLY want stronger ones, im pretty sure you're gonna have to go custom. Custom machined tie rod ends + High-end ball joints = $$$$$
Old Dec 12, 2013 | 09:02 PM
89ED's Avatar
Sorry I didn't post a picture.
Old Dec 12, 2013 | 09:40 PM
radex7's Avatar
Radius rod, and not a tie rod.
Old Dec 12, 2013 | 11:28 PM
rd91sib18c5r's Avatar
You could get an oem one and be fine, that one looks like it rusted half way threw.
You can get a traction bar they have beefier tie rods.
Old Dec 13, 2013 | 02:53 AM
Oh. Well shucks!
Com'on Mister Clean! Haha.
Anyways, I suggested Moog because it's a good brand. That's all. I know it's not any better than OEM.
OP, that is a radius rod. I would go with a traction bar. I got my innovative traction bar for $200 shipped, but it was slightly used. Or just replace with an OEM unit. The traction bar radius arms are beefier though.
Old Dec 13, 2013 | 09:26 AM
WhyTease's Avatar
If OP wants an Innovative EF traction bar, I have a used one I'm about to replace with an ESP kit because of the incompatibility with my F20B swap.
89ED, PM me if you're interested.
Old Dec 13, 2013 | 09:30 AM
Care to share the price? I feel like I paid too much for mine some times. The ESP kit is amazing. I love the square tubing.
Old Dec 13, 2013 | 09:49 AM
4drEF's Avatar
Keyboard Humorist
I would go with a $5 used OEM replacement.
Could be found easily from anyone that spent $200+ for an aftermarket bar.
Old Dec 13, 2013 | 10:07 AM
...yeah. I got some actually.
Old Dec 13, 2013 | 06:35 PM
89ED's Avatar
Anyone have any faith in this item.
http://www.ajdmparts.com/index.php?p...mart&Itemid=53
Old Dec 13, 2013 | 06:40 PM
89ED's Avatar
Still interested if cb7 or DA radius rods are compatible. Or another cars.
Old Dec 15, 2013 | 11:27 AM
You can always try and let us know.
Old Dec 15, 2013 | 09:22 PM
89ED's Avatar
I might be doing just that coming Tuesday or wedsday
Old Dec 17, 2013 | 04:52 PM
89ED's Avatar
Ok so today I went to the junk yard with not enough tools specificly 14mm wrench and 17mm deep socket. And I just checked my helms and it does say radius rod. So I asked about radius rod compatibility because mine rusted halfway threw and snapped as I left from a stop sign. I would take a good look at yours. Thank god I was not on the freeway. Leaving the stop sign and getting up to 15 it instantly started to pull to the side that broke. At about 20 mph I let go of the steering wheel. To see how bad it was and the steering wheel spun to the right at an alarming rate. So be carefully check yours out.
So compatibility right away eg does not use radius rods and *a* older teg. I had no pen and paper to catalog everything. I will tomorrow. For the most part all radius rods are bolted down using 17mm bolts except in two occasions. EF radius rods are all the same. Cb cd use two different radius rods per side. The right usually looks like picture 1 the left looks like picture 2 *I couldn't fix the angle. I'm not sure on thickness I'm taking a Mic tomorrow. Ill measure then. Even sixth gen accords used this mixed configuration but thicker I could tell just by looking at them. Picture 3. In 2 late 80's Teg and accord I found adjustable non shim type radius rods that were bolted to the front crossmember with the standard 17mm but were bolted to the lca with two 14mm bolts. Picture 4. Lastly I'm not sure if it was a first or second gen civic had radius rods with sway bar ends clamped to them. A pretty good idea I thought. Picture 3 & 4.
Old Dec 19, 2013 | 10:40 AM
89ED's Avatar
Pictures of the two different radius rods ef and 3rd gen accord
G2_Fella
Jun 25, 2009 01:44 AM
Charri
Oct 18, 2007 03:28 AM
92integra-R
Jul 20, 2006 03:53 PM
STPREZ
Jan 11, 2005 04:34 PM
Mista Bone
Dec 20, 2001 11:52 AM
