Newb Ls/Vtec
Old Dec 10, 2013 | 04:58 PM
atvrider's Avatar
Default Newb Ls/Vtec
Alright guys, my buddy is going to build an ls/vtec..he will use be using a b16a2 head. it is going to be mainly stock..b16 pistons, arp rod bolts and head studs, not sure on rings yet, probably oem. the head will probably have upgraded retainers and springs with skunk2 stage 2 tuner cams. my main question is will his stock p2t ecu work if he uses the b16 injectors without throwing a code? he will run a chipped p28 and probably bigger injectors with a decent tune for daily but for emissions we need a solution..also are the b16 and gsr water and oil pumps the same? I believe I read that the p72 oil pump would work not 100% positive though..
Old Dec 12, 2013 | 05:09 PM
bks84's Avatar
Loved
Default Re: Newb Ls/Vtec
uhm, well im not sure if the p2t ecu will work without codes, but itll run like crap and probably wont pass emissions.
as for the other questions...
b16, gsr and ITR water pumps are the same. they all have the same tooth count, so either will work. youll want to use a GSR timing belt though.
Honda used all the same "p72" oil pumps on all the OBD2 (96 and newer) B series engines. OBD1 though, I think is where people are saying theyre different.
Old Dec 13, 2013 | 12:02 PM
93egSLEEPER's Avatar
search "how to build a reliable ls/vtec" here on the site. BAMBAM did a write-up years back with tons of detail and info. Read up
Old Dec 13, 2013 | 08:12 PM
atvrider's Avatar
Very cool write up! Very helpful..so for the brief period to get emissions done..stock ecu and injectors with a regulator should be ok?
Old Dec 16, 2013 | 06:37 AM
What car is this going in? OBDI or OBDII?
Old Dec 16, 2013 | 01:39 PM
atvrider's Avatar
obd II..unfortunately so they have to plug it in with no light on
akire45
Apr 14, 2010 07:52 PM
DC2 Mang
120
Feb 27, 2006 08:54 PM
hondaluva
Aug 5, 2005 02:11 PM
mike5809
Jun 26, 2003 08:51 AM
