brake/tail lights won't turn off
Old Dec 9, 2013 | 04:39 PM
STOKEY's Avatar
Default brake/tail lights won't turn off
I have a 97 Civic EX. My brake/tail lights are staying on when I turn the car off. I found the source to be the brake light switch but instead of buying a new one I rigged up a bolt to the arm. Although it fixed the light problem it somehow locked my brakes up while driving and I burnt up my clutch. Replaced my clutch and brake light switch but even with a new switch the lights still wont turn off. Can't find a diagram for the relays so haven't been able to check that yet. Can anyone help?
Old Dec 9, 2013 | 05:26 PM
Lizardslap's Avatar
Default Re: brake/tail lights won't turn off
this is your problem happend to me I just replaced the stopper pad with a bolt and a nut
shows exactly your problem this link
http://www.findforgift.com/honda-civ...pper-retainer/
Old Dec 9, 2013 | 08:34 PM
slowcivic2k's Avatar
You adjusted the brake pushrod prior to "rigging the bolt" to the brake pedal. Now your brakes are applied permanently to some degree. Adjust the free play on the brake pedal to spec. Then diagnose any electronic problems with the lights.
If ALL your brake lights are on, then your problem stems from a common point to all the brake lights, IE the brake switch.
You will not burn up a clutch due to this problem. That is a separate problem.
gsxr-t-bag600
Dec 27, 2011 09:51 PM
jo7man4
May 30, 2009 03:50 AM
CONLESS
Jun 15, 2005 09:48 PM
94TealGSR
Oct 25, 2002 11:41 AM
