Del Sol won't start or crank
Old Dec 9, 2013 | 03:44 PM
Token_Tay's Avatar
Default Del Sol won't start or crank
Hi honda tech I have a 1993 Honda del sol S. After letting my car sit for a couple of weeks it no longer starts. Before that it started up everytime without fail. Now when I try there's no crank and none of the interior lights turn on either. I was wondering if anyone would no why this is happening.
Old Dec 9, 2013 | 04:31 PM
Jjbaehr's Avatar
Dead battery, have it jump started
Old Dec 9, 2013 | 04:46 PM
Token_Tay's Avatar
Default Re: Del Sol won't start or crank
I've tried to jump start it that didn't work. I made sure all my wires are connected and still nothing it won't even try to turn over.
Old Dec 9, 2013 | 04:55 PM
Sccacivic1997's Avatar
Battery
Old Dec 9, 2013 | 05:11 PM
Jjbaehr's Avatar
Than you jump started it backwards and popped the main 80amp battery fuse located in the underhood fuse box
Old Dec 10, 2013 | 07:20 AM
Token_Tay's Avatar
So I replaced the 80a fuse under the box and tried jump starting it again and still nothing. No trying to turn over and no lights interior or exterior. Should I try replacing the whole battery and terminal wires next?
Old Dec 10, 2013 | 07:31 AM
Lizardslap's Avatar
you should get a volt meter
Old Dec 10, 2013 | 10:46 AM
Former User's Avatar
If the battery is good, try cleaning and tightening the G3 transmission and G1 battery ground wire connections.
wongdang
12
Oct 24, 2013 12:58 PM
Laracorp
Apr 8, 2013 04:53 PM
jdm-lov3ej1
Aug 11, 2010 09:11 PM
jaydentaylor0021
Sep 26, 2008 07:38 PM
Richard.
Jan 11, 2005 10:29 AM
