jdm auto to manual swap question??
Old Dec 9, 2013 | 11:47 AM
ttjdmSIR's Avatar
Default jdm auto to manual swap question??
will this mount
http://www.ebay.com/itm/92-95-Civic-EG-Auto-to-Manual-Tranny-Conversion-Mount-Automatic-Transmission-ATM-/230739893188?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACivic&hash=item35b92b5bc4&vxp=mtr
work to convert a 96-98 jdm sir civic with a b16a from auto(non cvt) to manual??
Old Dec 9, 2013 | 12:21 PM
kyden's Avatar
Default Re: jdm auto to manual swap question??
you don't need a conversion mount. you just need a mount off a manual car.
Old Dec 9, 2013 | 02:56 PM
ttjdmSIR's Avatar
hmm, I've read that the stock manual mount sits lower than the auto one
Old Dec 9, 2013 | 05:19 PM
94EG8's Avatar
Seagull Management
You don't need (nor is one available) an auto to manual swap mount for a '96 - '00 Civic. All you need is the upper trans bracket from any '96 - '00 5 speed civic and ideally the upper and rear trans mounts (both of the rubber mounts have the same dimensions as the automatic versions, but the manual versions are stronger) '92 - '95 Civics/'94 - '01 Integras do require a special swap mount, but it's because the bracket is welded to the frame on those cars.
Old Dec 16, 2013 | 11:18 AM
ttjdmSIR's Avatar
hmmm, well i was doing some more research and came across this
"Very important
The automatic body of the car that you have will have a different transmission bracket off the frame than the manual 5th gen body, I'm sure the 6th gens don't have this problem b/c of the same type of bolt on mount that goes on the frame, but if you are doing a 5th gen auto to manual, then you can buy an AVID auto-manual mount which is a solid mount that goes up to the higher bracket, Hasport makes one also, You can get the mounts off of ebay for about $135-$175. Your other option is to drill out the spot welds out and then chisle off the bracket from the car, do the same to a manual car, clean up the parts and prep them for welding with bare metal, then following up with weld though primer, then weld the spot welds, clean them up, bare metal primer, primer surfacer, scuff, prep and paint, or you could just buy a mount and call it a day. the manual mount from the manual car WILL NOT work on the automatic car b/c it won't reach the higher bracket."
http://www.clubcivic.com/board/showt...o+manual+mount
Old Dec 16, 2013 | 11:35 AM
94EG8's Avatar
Seagull Management
It tells you exactly what I told you. It's needed for a 5th gen, but not a 6th gen.
I've done a few auto to manual swaps. You can't use an auto to manual mount on a '96 - '00 Civic.
Old Dec 17, 2013 | 11:28 AM
ttjdmSIR's Avatar
Aye thks for the advice again 94EG8
GSR_hatch936
Transmission & Drivetrain
Apr 1, 2014 04:44 PM
streethondar
Aug 27, 2010 07:21 PM
speedfreek128
Feb 18, 2009 03:00 PM
getnasty
Nov 17, 2005 12:56 PM
Py7h0n
Sep 14, 2004 03:34 PM
