d16y8 throttle body question
Does anyone know what belongs on the bottom of the throttle body? Right now theres a port that i isn't connected to anything, if i unplug it, then im left with WOT. i also have a hose in that area that i've plugged.
the black thing in the circled portion is the rubber plug, NOT a hose.
Thanks for the help.
EDIT: also, where does upsteram o2 get plugged into the harness? does it have anything to do with teh reverse sensor on the top of the transmission?
And I believe that there are 2 lines under the throttle body. One vacuum line and one coolant line. I think coolant goes into the side closest to the intake manifold
I understand what you're saying, but is there some sort of part that bolts up to that flush underside of the throttle body with two input/output ports?
I bought the motor and it came like that so im just trying to figure this out.
thanks again.
thanks again.
I think i have an auto throttle body, which has the ivac on the underside of the tb. in my case, its missing the ivac. thanks for the reply. looking for a auto ivac for a obd2 d series if anyone has one.
I got the answer i was looking for. i need a mt tb. auto wont plug right into my ex harness. id need to get the clip or an auto harness. just easier to get a mt tb. thanks boyz.
