D15B7 Idle issue - Need some suggestions
Old Dec 8, 2013 | 03:08 PM
BlackJacket's Avatar
Icon6 D15B7 Idle issue - Need some suggestions
I have been having idle issues with this Civic (95 DX Sedan), it's like a plague. Deleted the IACV and FITV which helped the surging idle however now the idle will dip low and then surge back up. Rinse. Spit. Repeat.
Here is a short clip of what it's doing -
When driving, the pulsating continues when you keep the rpm steady.
I have adjusted the idle screw but to no avail, the issue remains.
Any help is greatly appreciated.
Old Dec 8, 2013 | 07:25 PM
elly7b's Avatar
Default Re: D15B7 Idle issue - Need some suggestions
You should probably clean the IACV and FITV and put them back on or replace them.. They're there for a reason.. My car had the surging idle problem too.
Old Dec 8, 2013 | 07:45 PM
I just ordered them both. Should be here Tue. or Wed.
Old Dec 8, 2013 | 08:09 PM
Former User's Avatar
Have you bled the cooling system and checked for vacuum and intake air leaks??
Old Dec 8, 2013 | 08:11 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
It should idle fine once warmed up with out the iacv on fitv
There is a vacuum leak somewhere,
Inspect all hoses and make sure manifold bolts are tightened
Old Dec 8, 2013 | 10:07 PM
Bled the system and quickly looked for leaks, didn't go on an extensive search though.
dc4b20
22
Dec 3, 2012 09:54 PM
DC2*Integra
Sep 20, 2005 12:51 PM
Pele
Feb 9, 2003 01:01 AM
