Odd clicking when turning
Old Dec 8, 2013 | 07:34 AM
b20bFourDoorCivicLX's Avatar
Default Odd clicking when turning
IM hearing what i would usually hear with a bad axle...ive had my car jacked up and havent seen and thrown grease from a bad axle boot
any ideas
Old Dec 12, 2013 | 12:13 AM
MisereNoire's Avatar
Default Re: Odd clicking when turning
While not a common occurence, a CV joint CAN fail without a loss of lubricant...if the joint is stressed enough, it can cause damage to a "spider" in the joint. You should also check that your axle nuts have been properly staked and arent loosening on you. aside from that, you may want to check your ball joints/endlinks/rotors for loose fitments/obstructions/foreign objects. good luck.
Old Dec 12, 2013 | 03:40 AM
B_Swapped93's Avatar
unless something is rubbing then there's nothing else it can really be that "clicks", clicking is one of the tell tail signs of a bad CV joint. no the boot doesn't have to be ripped or gone for it to go bad.
Old Dec 12, 2013 | 04:31 AM
purgat0ry's Avatar
exactly like b_swapped said, boot failure doesn't always have to occur to lose a CV joint.
Also...
Old Dec 17, 2013 | 05:22 PM
thanks guys...
Bush-15
May 26, 2009 09:46 AM
grkblood13
Transmission & Drivetrain
Apr 2, 2009 05:09 PM
mikeunreal
Nov 22, 2005 08:42 PM
tRex99
Sep 14, 2004 09:53 AM
GReddy SI
12
Jul 17, 2003 04:07 AM
