Transmission & Drivetrain Gearboxes, Differentials, Clutches
D16y8 transmission pressure plate fingers bent?
Old Dec 8, 2013 | 06:16 AM
EG-SIXV-TEC's Avatar
Post D16y8 transmission pressure plate fingers bent?
im swapping my d motor. ok i drive the car manual with it without any big of a problem the exedy stage 1 clutch i have for like a year.
The only problem is that it sometimes grind only at 3rd gear when shifting. sometimes pops out of gear when driving big turns. when drifting u turns. other than that it drives smooth. The shifter bushings are all worn out i will be replacing that soon.
when i took off my trans the pressure plate fingers are slightly bent. bent like 3 fingers or four slightly inward. its not flush with the other fingers. wtf?
how did this happen. i cant afford another one at the moment but is this still usable? drivable? did i cause it to bend when i removed the transmission?
Old Dec 8, 2013 | 08:41 AM
94EG8's Avatar
Seagull Management
Default Re: D16y8 transmission pressure plate fingers bent?
No it's not usable. The diaphragm spring in the pressure plate is probably broken.
Old Dec 9, 2013 | 08:17 PM
slowcivic2k's Avatar
Your pressure plate is broken, replace it, along with the release bearing. Inspect the flywheel for wear and machine or replace as required. Any bolt heads missing?
And don't forget the pilot bearing!
Old Dec 12, 2013 | 12:06 AM
Post Re: D16y8 transmission pressure plate fingers bent?
the clutch disk is okay/no spring broken. but the pressure plate fingers slightly look bent.
the bolts are all there.
what torque spec are the flywheel bolts. also what torque spec are the pressure plate.
and what locktite do you recommend red/blue locktite.
it seems it have some locktite on the old threads do u recommend removing it with a wire wheel?
Old Dec 15, 2013 | 01:32 PM
MattAttack811's Avatar
Yeah I would go ahead and replace all the parts while you have the transmission down.
Prelude209
Dec 13, 2010 06:20 PM
Sohc Driver
Jul 26, 2004 08:09 PM
Type R 702
Nov 18, 2001 05:01 AM
