96 accord lx not starting-battery tested fine
Old Dec 7, 2013 | 04:46 PM
accord96lx's Avatar
Photogenic
Photoriffic
Shutterbug
Default 96 accord lx not starting-battery tested fine
When I turn the key the lights on the dash do a flicker but it doesnt try to crank at all. There is a cover shim cap on the neg post since the neg cable wont tighten enough without it. I did check the battery and even charged it but it will not try to turn over.
What are the other things to check? Can a starter be tested or just replace it?
Old Dec 7, 2013 | 10:46 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: 96 accord lx not starting-battery tested fine
Try moving the neg cable around while someone else cranks it....
Old Dec 8, 2013 | 12:11 AM
holmesnmanny's Avatar
also check the starter and see if it's loose...if it's not connected all the way cause the bolts backed out it's not going to start
if it checks out fine, hit it with a hammer, if it starts then then it's normally the solenoid and/or starter contacts that's bad
Old Dec 8, 2013 | 05:19 PM
Suma's Avatar
make sure the wires on the starter haven't wiggled off.
Old Dec 11, 2013 | 04:44 PM
Lost Again's Avatar
Auto or manual trans?
Have a voltmeter, when trying to start the car are you getting ~12v to the small BLK/WHT wire to the starter solenoid?
Old Dec 16, 2013 | 02:59 PM
cschlick's Avatar
if lights only flicker, most likely a bad connection,
if everything works steady but dims/cuts out when key turned to START, check clutch/neutral interlock switch
Old Dec 16, 2013 | 03:40 PM
GhostAccord's Avatar
What are the current temperatures in your area, is your battery rated for appropriate cold cranking amps?
Have you had the battery cranking amps tested? A battery can be charged and hold a charge but still not have enough amps to turn the engine over.
Old Dec 31, 2013 | 11:46 AM
accord96lx's Avatar
Photogenic
Photoriffic
Shutterbug
Sorry for the late follow up but in the end it turns out that even though I had charged the battery the evening before and was able to get the interior lights and headlights on, the next morning it was dead all over again. The battery was a NAPA battery I had for 4-5 years and it reached a point where it would no longer hold a charge. Went to get a new battery at Advance and after installing it has them check the system to make sure it was charging properly, and it all checked out.
Thanks for the replies.
mrbangchang
Nov 23, 2014 10:04 AM
David1946
Nov 7, 2012 01:09 PM
Macswer
Jun 6, 2008 08:41 PM
drintegra
Aug 4, 2006 04:06 AM
honest.hank
Aug 19, 2005 09:19 PM
