Stripped Bolts on Valve Cover
Old Dec 5, 2013 | 08:15 PM
marcelosm's Avatar
Default Stripped Bolts on Valve Cover
I feel like I keep finding little things wrong with this Del Sol s D15B7 every day. So I finally found the time to go ahead and do a valve lash adjustment and when I try and take off my valve cover I notice that one of the nuts is just spinning in place. The bolt looks stripped and one other one looks just as bad. I can't take the valve cover off because of this though. I tried prying something under the nut to try and get it to catch while I turned it but it was too flush with the cover.
Anyone have any experience taking something like this off? Can you just buy a new nut and bolt once you do get it off?
Old Dec 5, 2013 | 08:19 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Stripped Bolts on Valve Cover
Assuming it's the nut that's stripped and not the stud, yes, you can replace it with whatever. If it's the stud, you can find a replacement fairly easily, but not "drive down to Lowes" easy.
Old Dec 5, 2013 | 08:41 PM
marcelosm's Avatar
Yeah it's the stud that is stripped or at least it looks that way since the top looks pretty bad. Are they easy to replace?
Old Dec 5, 2013 | 09:11 PM
NotARaCist's Avatar
Extremely easy. If it's stripped on the head side, it'll just pull straight out with a little wiggling. If it's stripped on the nut side, the nut should pull straight off with a little wiggling. Once you have the VC off, soak it in some penetrating oil, clamp it with some vice grips, and rotate it out.
Old Dec 5, 2013 | 09:28 PM
marcelosm's Avatar
Ugh I wish I could take a pic of it right now because I am confused. The valve cover has 4 studs and 4 nuts that hold it in place. Two of the studs look very stripped on the top part of the valve cover where the nuts are. Can those be stripped studs be replaced?
Old Dec 5, 2013 | 09:32 PM
NotARaCist's Avatar
Save this image, open it in paint or something, and label the nuts you're talking about if you can't take a pic.
Old Dec 5, 2013 | 09:45 PM
marcelosm's Avatar
I need to take off all four that are circled but the red ones are stripped. Mine aren't those acorn nut things. I have regular nuts on there and they just spin without coming out. Thanks for the help by the way.
Old Dec 5, 2013 | 09:47 PM
NotARaCist's Avatar
If they're just spinning freely, clamp some vice grips on the top of them one at a time, and wiggle them straight up and out. Then you'll be able to figure out where they're stripped.
Old Dec 5, 2013 | 09:49 PM
marcelosm's Avatar
I'm pretty sure the stud is the one stripped. The top of the stud looks all f-ed up. Where could I find some more of those studs? What are they called do you know?
B_Swapped93's Avatar
angle grinder/cut off wheel, then vise grip them when the VC is off they're only torqued down to 10ftlbs or hand tight if done properly. Honda dealer is where you'll have to get them and look at a parts diagram not everything is going to spoon fed.
Old Dec 5, 2013 | 09:53 PM
marcelosm's Avatar
Thanks a lot. Yeah you're right, shouldn't get spoiled here. I think I got it from here.
Old Dec 5, 2013 | 09:54 PM
http://www.hondaautomotiveparts.com/...A5MT&catcgry5= "here it's under head cover/cyl head" rest is on you.
Old Dec 5, 2013 | 10:55 PM
NotARaCist's Avatar
Wrong link. WAY wrong link. OP has a Del Sol S with a D15B7, not a 99 Civic with a D16Y7.
http://www.hondaautomotiveparts.com/...3-95+S%2CSI%29
#17 is the acorn nut. You don't need that specific part - like I said, you can just swing by Lowes and get the right sized nut.
http://www.hondaautomotiveparts.com/...%28+93-95+S%29
#14 is the stud. It is also a cam cap bolt, so yes, you do need that specific part. You also need to start praying that it's the stud that's stripped and not the head. Head is aluminum, stud is steel. Aluminum strips first 9 times out of 10.
Old Dec 5, 2013 | 11:24 PM
marcelosm's Avatar
Yeah I figured it was the wrong one but its fine. I had already found the right one when I saw his link. I am almost sure that it is the stud #14 that I am gonna have to replace once I manage to get the nut out. It just looks like the top where the nut goes that is messed up. But yeah I hope that it is that simple. I'm gonna drop by the Honda dealer tomorrow anyway and see if I can pick up two replacements. I'll try and post a pic tomorrow.
Old Dec 6, 2013 | 12:29 AM
I have it saved for my dd civic....calm down.
liljohn850
Jun 5, 2009 04:23 PM
butter99
Jan 3, 2009 07:49 PM
Import Prelude
Apr 18, 2007 02:50 PM
charjacq
Jan 29, 2004 04:24 PM
bartek_b
Apr 15, 2003 11:21 AM
