B18 trans problems
Hey guys i have an 00 civic with a b18a1 and an s80 trans out of a 94 integra. My question is my car just stopped moving but when the trans is in gear the speedo still moves. Ideas?
You will notice one of the axles turning, either the inboard joint or the shaft, the outer joint is prone to breakage. If you do not see an inner joint or one of the axles turn, you have a broken differential.
