TPS volts different in ECU plug
Old Dec 5, 2013 | 03:01 AM
carlos8's Avatar
Default TPS volts different in ECU plug
hi, like the tittle say I get different voltages, the TPS plug reads .45v and when I measure in the ECU pin d11 I get .39v
This is acceptable or need to check for open wire?
Old Dec 5, 2013 | 03:34 AM
dfanatic86's Avatar
Default Re: TPS volts different in ECU plug
are you back probing pins 2+3?
Old Dec 5, 2013 | 04:28 AM
Lizardslap's Avatar
check it at wot it should go .48 to 4.5v if not adjust its well worth your time
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Old Dec 5, 2013 | 04:40 AM
carlos8's Avatar
Yes, D11 + D22 at ECU plug = .39v
TPS plug middle red wire + battery neg.= .45v
Lizard I not having problems with the TPS calibration, it increase and decrease flawless without spikes or death spots.
Only a slight difference in volts between sensor plug and ECU plug.
Old Dec 5, 2013 | 05:28 AM
HondaPartsHero's Avatar
Technical Hero
Wha are the resistance readings of the wires?
Old Dec 5, 2013 | 05:59 AM
carlos8's Avatar
how I measure the resistance in this wires?
Set the voltmeter to RES. negative prove to battery neg. and positive prove to the wire to be tested?
Old Dec 5, 2013 | 07:35 AM
carlos8's Avatar
TPS resistance.
1 + 2 = .66
2 + 3 = 4.84
Also I have low voltage between d17 + d21 = 4.0v with the MAP disconnected instead of 5.0v
I think my ECU is fried.
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
kinvid22
Nov 8, 2003 10:18 AM
