Omex Rev Limiter Fitting/Coil Negative Wire
Old Dec 4, 2013 | 01:40 PM
DanB93's Avatar
Default Omex Rev Limiter Fitting/Coil Negative Wire
I'm attempting to fit my single coil omex rev limiter to my civic because the previous owner had the limiter removed and I'd like to keep my engine safe.
To wire it in I need to take a wire to both the coil + and coil - . Where can I find these inside the dizzy cap? Every connection I measure seems to have 12v?!
Inside my distributor looks like this: http://easyautodiagnostics.com/honda...s/image_12.jpg
It's '94 B16A2 OBD1
Thanks.
Old Dec 4, 2013 | 10:10 PM
crazyhouse2011's Avatar
Default Re: Omex Rev Limiter Fitting/Coil Negative Wire
Keep engine safe = no racecar driving habits.
Old Dec 4, 2013 | 10:18 PM
NotARaCist's Avatar
I never narc'd on nobody!
The stock rev limiter is integrated into the ECU. Easiest way to fix it? Get the proper stock ECU for the car, or have your current ECU re-tuned to include a limiter.
Old Dec 5, 2013 | 02:26 AM
DanB93's Avatar
Yes I'm aware of that but that's not what I asked is it. It would be easier for me to just wire this one in for now.
The coil clearly has a + and - marked on it yet I am measuring 12v at the - . Why and what connection should I use for the negative?
Here'a a pic of my coil:
Old Dec 6, 2013 | 05:17 AM
DanB93's Avatar
Bump.
Old Dec 6, 2013 | 05:19 AM
B_Swapped93's Avatar
just get the proper ecu or more simply stop driving you econ-o box like a race car there's NO reason you should be hitting close to the rev limiter daily driving it.
Old Dec 6, 2013 | 06:03 AM
DanB93's Avatar
That's not what I asked but thank you for your input.
Old Dec 7, 2013 | 03:06 AM
DanB93's Avatar
Bump
Old Dec 8, 2013 | 01:35 PM
DanB93's Avatar
Bump.
Old Dec 8, 2013 | 03:40 PM
HondaPartsHero's Avatar
Technical Hero
http://www.msdignition.com/uploadedF...structions.pdf
"2. Locate the coil wires and note their color and location. On the majority of Honda or Acura engines, the Black/Yellow wire is positive. The coil negative wire is generally White/Blue, Blue, Green/Yellow or Green. In some cases, the coil itself is marked negative (-) and positive (+)."
Old Dec 8, 2013 | 04:29 PM
DanB93's Avatar
Thanks for your reply.
My coil is marked + and - but the confusing part is that I measure 12v at the - . I fail to understand that?
Old Dec 8, 2013 | 05:25 PM
Marvin1985's Avatar
Improper measuring. That's why.
Old Dec 8, 2013 | 06:36 PM
Z3120's Avatar
http://omextechnology.co.uk/OMRLCLC.pdf
It's a coil, you'll get 12v at both point. Just wire per instruction.
Old Dec 9, 2013 | 06:53 AM
DanB93's Avatar
Thanks for that I just wanted to make sure I wasn't going to **** anything up, I haven't come across an ignition system like it before.
It works as it should.
Silver.007
Oct 12, 2005 06:50 AM
vegaskurt
Oct 4, 2005 01:29 PM
91si pumpkin2
Jun 21, 2005 09:31 PM
vteckilla7
Aug 8, 2004 01:41 PM
