Transmission & Drivetrain Gearboxes, Differentials, Clutches
LSD problem ?
Old Dec 4, 2013 | 05:22 AM
alperx's Avatar
Hello..
I got an Type-R LSD from a friend today, and I saw 3 teeth damaged.
is it a problem ? Should I give it back ?
I guess this is the final drive. Can i use mine ? ( '91 Integra LS cable-tranny)
Thanks..
Old Dec 4, 2013 | 09:18 AM
Aquafina's Avatar
Default Re: LSD problem ?
You cannot use the ITR ring gear with your countershaft and you cannot use your ring gear with the ITR LSD. I do not know of any final drives available that will allow you to use the ITR LSD in your trans.
Old Dec 4, 2013 | 11:20 AM
alperx's Avatar
for info :
my transmission is Q1. this is not found in the USA. my final drive is 4.4.
so it's not possible to use this LSD in my car in any way ?
unlucky I am..
Old Dec 4, 2013 | 12:08 PM
parts@synchrotech's Avatar
If your transmission is similar to the one on the right (89-91 B-series)..It will NOT work.
If it is like the one on the left. It can be used but, will require a new ring gear and countershaft for the correct fitment of your Type R LSD. You will also need to do a lot of grinding and use the correct differential bearings and shim.
Old Dec 4, 2013 | 12:17 PM
alperx's Avatar
ok I will check.. thanks..
Old Dec 4, 2013 | 12:32 PM
alperx's Avatar
one more question : does the the pictured cracked tooth cause any problems ?
Old Dec 4, 2013 | 12:47 PM
That is not usable unfortunately.
Old Dec 4, 2013 | 12:53 PM
alperx's Avatar
thanks very much..
Old Dec 6, 2013 | 11:30 AM
alperx's Avatar
sorry - I opened the package and saw that this LSD is not OEM ?
what is it ? can you identify ? I could not find this itr lsd from google..
Old Dec 6, 2013 | 04:04 PM
David @ Synchrotech's Avatar
This is an aftermarket B16 LSD. You should be able to reuse your Q1 FD set with it.
Old Dec 6, 2013 | 11:48 PM
alperx's Avatar
Amazing ) many thanks
Old Dec 8, 2013 | 02:37 PM
Aquafina's Avatar
That is an OBX LSD. I highly suggest inspecting it before reassembling the trans.
Old Dec 9, 2013 | 12:27 PM
alperx's Avatar
thanks, what should I check about it ?
How do I inspect ? I guess not many people know what it is here
Old Dec 11, 2013 | 09:23 AM
Aquafina's Avatar
Check the runout on it. Also take it apart and inspect the internals.
ekcivic2
Jun 1, 2014 03:29 PM
turtleef
May 2, 2012 06:49 AM
hondafleet82
May 25, 2009 07:01 AM
SupaFly_Honda
May 12, 2004 05:12 AM
TeamSTEALTH GSR
May 21, 2003 09:17 AM
