Valve adjustment drag?
Old Dec 3, 2013 | 08:35 PM
Honda knowledge's Avatar
Icon2 Valve adjustment drag?
Hey all,
Doing a valve adjustment on my 93 Honda accord for the first time. Now, everything is pretty basic, except for what "slight drag" feel like? While I slide the feeler in and out, the angle of the feeler should be perpendicular to the valve head below and perpendicular to the rocker above it? Right? Cause I have noticed that the drag increases or decreases at different angles. If anyone could clarify this I would appreciate it.
Old Dec 4, 2013 | 03:25 AM
blackeg's Avatar
Default Re: Valve adjustment drag?
I used to fuss about slight drag a lot. Recently I just started tightening it until I couldnt move the feeler gauge and then backing it out between 1/8 and 1/4 of a turn
Old Dec 4, 2013 | 04:06 PM
spAdam's Avatar
Loved
Community Favorite
The tolerance band is plenty wide enough to feel for the valves. If you have some drag or even if they are a little snug you are fine.
OP, are you using flat shims or the ones with a fold? ie:
http://www.amazon.com/gp/aw/d/B0009OR94M
Old Dec 4, 2013 | 05:42 PM
IN VTEC's Avatar
Just go / no-go check it and it's more than good enough relative to the tolerance given by the mfr.
Old Dec 5, 2013 | 05:57 AM
kyden's Avatar
just get the next size up, it shouldn't fit. the next size down should go in with no drag.
Old Dec 5, 2013 | 07:24 AM
spAdam's Avatar
Loved
Community Favorite
AKA go/nogo
Old Dec 9, 2013 | 08:08 PM
I am using the feelers with the bend in them. I appreciate all the feedback from everyone. I am just gonna stick the feeler in there and tighten it down snug while its stuck in there and then back it off just a bit. Good idea
Old Dec 10, 2013 | 11:13 PM
motoxxxman's Avatar
best way to do it is the go/no-go method. feeler that is within spec should fit, feeler that is 1 size larger than spec should not fit. this eliminates all guesswork and guarantees it is within spec.
A_Rotary_Guy
Jan 20, 2008 11:54 AM
CardDealer
Mar 10, 2004 06:25 PM
Hoosier Daddy
Jan 27, 2004 10:34 AM
Phoenix_ITR
Feb 5, 2003 05:19 PM
Fooser
Feb 19, 2002 09:56 AM
