d16z6Tcrx 12.4@107.66 1.8 DD
Old Dec 2, 2013 | 05:02 PM
d16z6Tcrx's Avatar
Default d16z6Tcrx 12.4@107.66 1.8 DD
Took the car to the track yesterday before it closed. been dialing in this setup all year. last time out it went 13.86 @ 99mph with a bad bog and slipping clutch. switched over to the exedy stage one and got aggressive with the tune. Street raced it a lil bit and got excited about how it was running. Took it to the track yesterday with goals of running a 12.9x-13.1 and be happy with it. first pass went 12.4@107. Beyond pleased. total shock. this was the best pass of the day. backed it up with a 12.6@ 106.
96 cx uncut full glass removed rear sears and plastic.
ls/vtec
gsr head stock ports
supertech valve springs
skunk2 pro2s
skunk2 intake manifold
68mm tb
pr3 pistons
stock rods and rod bolts
ebay try-y header
ebay 500cc injectors
ebay 3" intake
exedy stage 1
22x8x13 m&h slicks
skunk 2 coilovers on kyb agx
pump 93
Old Dec 2, 2013 | 05:40 PM
AllMtrRex's Avatar
Default Re: d16z6Tcrx 12.4@107.66 1.8 DD
Congrats that's a great slip for such a simple setup. How much does the car weigh with driver and what rpm/tire psi combo are you launching at?
Old Dec 2, 2013 | 06:14 PM
d16z6Tcrx's Avatar
Its never been on the scale. Its uncut full interior minus rear seats n plastics. Full heat n wipers all glass. Ran 22s on bogart flystars. Psi was best at 10. Any lower would bog hard.
Old Dec 4, 2013 | 12:49 PM
seelback's Avatar
awesome setup. i like how simple it is. im digging the scatter shield!!!
Old Dec 4, 2013 | 01:15 PM
93egSLEEPER's Avatar
This is very impressive. Simple and works. Gives me tons of confidence in the B20V setup I'm building and want to see 12's with.
What tranny are you running?
With a nice ported head and a better header I think an 11 could be in reach.
Old Dec 5, 2013 | 10:35 AM
d16z6Tcrx's Avatar
thanks!
thanks! its a itr trans with 4.7. i think with a higher launch and better track prep it could have went a 12.2x. i will be porting the head over the winter and swapping in a built b20.
looking into a plm header too.
Old Dec 5, 2013 | 10:36 AM
d16z6Tcrx's Avatar
here is a better video.
Old Dec 5, 2013 | 11:24 AM
seelback's Avatar
Originally Posted by d16z6Tcrx
thanks!
judging by your hp, my guesstimation of weight and your 60ft e.t. and mph you've produced so far, I wouldnt se that much of an improvement from a higher launch and better prep. your 60ft is awesome and your mph is about spot on with your hp numbers
Old Dec 5, 2013 | 12:01 PM
d16z6Tcrx's Avatar
if u listen to the video it dead hooked off the launch n died the motor down a few hundred rpm. same tire pressure and 3/400 rpm more would have taken .02/3 off the 60 an maybe .03/4 off the 330. also the track was cold. (40 deg) but never the less im very happy with the .4x
Old Dec 5, 2013 | 02:03 PM
mar778c's Avatar
Community Builder
Community Influencer
great job
Old Dec 6, 2013 | 11:13 AM
d16z6Tcrx's Avatar
Originally Posted by mar778c
great job
thanks!
JerzyFin3zt
Transmission & Drivetrain
10
Aug 21, 2013 05:47 AM
Cameron52
Apr 7, 2012 12:29 PM
umair
Jun 16, 2009 08:54 PM
hayabusa160
62
Jan 4, 2005 02:35 PM
rolow
Jan 8, 2003 04:45 AM
