H22 EG build thread
Old Dec 2, 2013 | 03:43 AM
dfanatic86's Avatar
Default H22 EG build thread
Hey guys, been lurking on honda-tech for years now and I've decided to to my first official build thread.
So my journey began about a year ago when I had a sweet deal thrown at me. 91 Civic Si with a h22a4 for $500. Knowing the previous owner hacked everything and took every possible shortcut, I jumped on the deal and began making preparations to bring the h22 back to life. I was originally going to keep the h22 in the EF chassis, but to make a long story short it wasn't worth it. So I decided on an EG chassis as my canvas. As of now, Im just getting everything on the engine back up to spec.
This is the hatch the day I bought her:
Cleaning some parts up:
Dirty throttle body:
Clean throttle body and new tps:
Cleaning head and block:
Almost done:
Some goodies:
Finished Valve Cover
Not finished yet, still waiting on injector seals from honda and fuel rail spacers
Mounts:
More goodies:
Just ordered: 93 Accord shift assembly
Ordered from honda: ECT and IAT
Old Dec 2, 2013 | 06:07 AM
dfanatic86's Avatar
Default Re: H22 EG build thread
Question for you guys, I wanna remove the IACV and FITV all together for a clean look. I live in FL so cold weather is not a problem. Other than that are there any other things that could mess with my idle?
Old Dec 2, 2013 | 05:00 PM
dfanatic86's Avatar
Not too much progress today. Did a little more cleaning of the transmission and mock up to see how things will look. I did manage to prep the removal of the h22 for tomorrow.
Old Dec 2, 2013 | 06:49 PM
civicb1812345's Avatar
looks good man, ive always wanted a h22 swap
Old Dec 3, 2013 | 06:32 AM
averyvm's Avatar
Engine is clean! What did u use to clean it?
Old Dec 3, 2013 | 06:59 AM
dfanatic86's Avatar
Thanks! I've been using a wire wheel on drill for the easy areas. And using a wire brush for hard to reach spots. I then follow up with a brass brush afterwards.
Old Dec 3, 2013 | 06:31 PM
dfanatic86's Avatar
Update! Shift assembly came in
I managed to get the h22 out. Sorry no pictures of the process I forgot my SD card at work. On the plus side of things my IAT, ECT, all the injector o-rings and misc bolts/screws came in from Honda. All that's left is the axles/halfshaft and a chassis! Stay tuned!
Old Dec 3, 2013 | 07:47 PM
Marvin1985's Avatar
Nice. In for results. Did you spray paint the parts after cleaning?
Old Dec 4, 2013 | 02:13 AM
dfanatic86's Avatar
Thanks man and no paint. Don't really like the idea of painting engine parts. Although the thought has crossed my mind but I tend to keep engines clean. I might do the manifold in black. Still don't know on that.
Old Dec 4, 2013 | 05:18 AM
Leah Goring's Avatar
like how clean that engine is looking, nice job. I wouldn't personally paint the manifold, I would get it ceramic coated has a good finish (if you get a colour coat) and it helps with performance.
Old Dec 4, 2013 | 12:02 PM
dfanatic86's Avatar
Thanks I will keep that in mind!
Old Dec 4, 2013 | 04:53 PM
dfanatic86's Avatar
Update! At the beginning of this thread I didn't state why I decided to abandon the chassis. So I figured pictures could speak loud than word. Read for the ?
Here is the wrong way to 1. Weld a mount in a mount and 2. Hack you frame to bits to fit the h22.
To top it off I realized the slave cylinder needs replacing.
Ready for another one?
Ouchies!
Shift assembly split?!
This one tho is by far my favorite.
Now that's what I call custom.
So now you should understand why I bought it for $500 and why I'm putting the h22 in another chassis. Okay so that was the bad. Here's the good
I managed to save the GSR seats that came with the car. I totally thought they weren't worth a crap.
Just a few things missing on the seats, cleaned up pretty nice tho.
NRG steering wheel.
I plan on polishing it and hopefully finding a place that cleans suede! Any recommendations?
Old Dec 4, 2013 | 05:18 PM
albertoG87's Avatar
Briannnn!!!!!!! You didn't tell me that you were making a build thread. Who's hatch did you buy?
Btw, you should track down your old EF and drop the swap on that. I loved that Hatchie.
Old Dec 4, 2013 | 05:36 PM
dfanatic86's Avatar
I figured you would stumble on this and realize it was me! And yea the red 91 Si would have been perfect!! And I'm actually going EG or possibly DC. When I get some cashed saved I'll be deciding then. Which is also why I haven't ordered axles. I have plenty to work with for now. BTW how the hell did you know it was me?
Old Dec 4, 2013 | 06:26 PM
albertoG87's Avatar
You can't hide, I'm military...I'll find you anywhere bruh!
Old Dec 7, 2013 | 05:37 AM
dfanatic86's Avatar
Update! Injector O-rings, ECT, IAT and misc screws. I forgot the insulators for the injectors. It's all good though I still need to order some oil pump seals, throw out bearing, transmission bolts, oil cooler seal, water pump and reverse switch.
Once I get the insulators, Ill be getting the manifold cleaned a final time before reassembly. Also I'm thinking about getting a FITV and IAC block off kit. <- Anyone care to chime in on this? Also after reading a bit, I might be getting some ARP intake manifold bolts (longer) as I have read there's not much of the threads to grab when using a Hondata IM gasket.
Old Dec 19, 2013 | 11:06 PM
albertoG87's Avatar
Updates?!?!?!
Old Dec 23, 2013 | 07:17 AM
dfanatic86's Avatar
Sorry guys not much being done due to the holidays. I'll probably be collecting more parts in the new year. Some of the things I know ill be needing are:
-Oem timing belt
-Timing covers and all hardware
-Kaizen Speed manual tensioner
-Oil cooler gasket
-Oem water pump
-P/S bracket and all associated hardware
-A/C bracket and all associated hardware
-Rear main seal
-Thermostat
-T2W4 transmission
Old Dec 27, 2013 | 03:35 AM
dfanatic86's Avatar
Update!
Found a set of timing covers
AC bracket ordered
So my goal for this is simple, I want that super OEM look. Hopefully the end result will be a Civic that looks like it should have came with a h22. I have already organized all the parts I need. I plan on taking my time and doing right the first time. Stay tuned, lots more to come. As always Im open to suggest and feedback!
Old Dec 29, 2013 | 05:22 PM
dfanatic86's Avatar
So I managed to get the h22 completely out of the EF. I had to get a little creative to get the engine out.
So this what I did, and this is a personal first for me. Not to mention I have to no one around to lend a hand. (Don't pay attention to the crap *** header, Im going with an oem one with heatshield )
Sorry no pictures of the engine on the hoist, but you can imagine how it looks. With that being said I have gained back some much needed space in the garage. Later this week I'm getting the car hauled off for the arrival on the next canvas. <- Still undecided on what to get.
Seems like there's no end to the neglect this engine has endured. Looks like I'll need to take the pump off or possible buy a new one. <- not really I enjoy this
This is why I purchased another set of timing covers. I also order all the hardware/gasket associated with the covers. (Yes, I know. I'll be buying another crank pulley lol)
Back shot of the block
Hey what do we have here?! smh
I have a few things I'm waiting for from Honda. I have yet to talk about the goal of this build so I'm deciding now would be a good time. For starters I don't plan on building this bottom end. I do plan on sourcing a complete h22a1 long block ( closed deck ) and building that slowly. With that being said my ideal chassis would be 92-95 Civic hatch with a h22 A/C and P/S super oem style goodness. And I really do mean OEM style. Hopefully in the near future I'll be doing a NSX brake upgrade along with a rear disc conversion. Stay tuned! As alway feedback is appreciated!
Old Dec 31, 2013 | 05:18 AM
dfanatic86's Avatar
Possibly found the chassis I've been looking for. And it fit the bill perfect. 1994 Civic Ex Sedan! The H22 will be a PnP in affair. 4 doors for the family, 4 wheel disc brakes and a sunroof!
Old Jan 8, 2014 | 10:02 AM
dfanatic86's Avatar
Update! I didn't get the chassis I wanted so I'm still looking! On a side note I ordered a Kaizenspeed tensioner, timing belt, OEM water pump and oil pump seals. Once I get these parts in, the timing side of the engine is done minus the timing covers. I managed to get the new camshaft seals and cam seal installed. I post some pictures later tonight.
pinoy2o9
22
Jan 23, 2009 06:14 PM
beefjerky
Sep 11, 2005 03:58 AM
jaydmegsix
Nov 13, 2004 05:35 PM
